I use Ubuntu 16.04 and I get update problems after installing skype. When I try to install updates by using Software Updater, it stops and gives an
The package system is broken
error. And says:
Check if you are using third party repositories. If so disable them, since they are a common source of problems. Furthermore run the following command in a Terminal: apt-get install -f
I disable third party repositories and even remove mendeley from the list but the problem did not solved. I tried apt-get install -f command, it gives also problem and says:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
How can I solve this problem?
