-1
Following error output on apt-get install -f:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
dufte
  • 14,198
  • 41
  • 43
You should use root account or sudo when you want to change/install/fix packages with apt-get or apt or dpkg.
Defman
  • 101
As other people suggest your problem is that you do not have permission, to install something you have to use the sudo which will give you the root.
FieryCod
  • 407
