I got a Linux OS today. I was playing around the terminal, downloading some things that I find interesting, but I think I have run a command that messed the apt-get command. Whenever I try to install something, I receive an error message:
$ E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
$ E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
There are no processes updating anything, and I already tried to manually delete the lock files.
I was trying to use Wireshark and nmap, and there are some commands that I have run, and I believe that they are messing the lock files :
$ sudo usermod -a -G wireshark rafael
$ sudo chown root /usr/bin/dumpcap
I was not able to use Wireshark because of permission problems, so I tried to give it permission with these commands, obviously I got it on random forums on the internet (I'm a total newbie on the Linux commands)
How do I get the apt-get command running again ?
Raffaell
You need to run apt with root privileges
sudo apt-get install <something>
sudo apt install <something>
Do not mess with locked processes and files. Ubuntu Linux technology has advanced to a degree that there will probably never arise the need to remove such blocks.
Good luck.
Giorgos Saridakis
  • 768
  • 13
