-1
This is displayed when I try to install Snaphu in Linux
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
How can I solve this problem?
Zanna
  • 72,312
anu
The below error means that you should execute the command as root, using sudo
"E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Try again using:
sudo command
e.g.
sudo apt install snaphu
Yaron
  • 13,453
