I would like to install the gpointing-device-settings package which I found on the Launchpad website https://launchpad.net/ubuntu/+source/gpointing-device-settings
I tried:
apt-get install gpointing-device-settings
but I get the following reply:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
I also tried
add-apt-repository ppa:gpointing-device-settings
and got
Error: must run as priviledged user
Can anyone point me in the right direction please as I seem to have got my brain into a loop...
Pilot6
  • 92,041
Simon
  • 4,843
as it saying you need to do the procedure as root user. simple add sudo. In Ubuntu to install anything you must be a root user.
I mean
sudo add-apt-repository ppa:gpointing-device-settings
sudo apt-get update
sudo apt-get install gpointing-device-settings
then you will have it installed .
Raja G
  • 105,327
  • 107
  • 262
  • 331
There is a rather undocumented command in the Synaptics touch pad driver:
synclient TouchpadOff=0/1.
Set it to '1' to disable the touch pad. To make it persistent, add a startup program with this command (in Ubuntu or Debian). Neat, isn't it?There is a rather undocumented command in the Synaptics touch pad driver:
credits:firdavis on url :-http://xmodulo.com/how-to-disable-touchpad-on-debian-ubuntu-desktop.html
Ravexina
  • 57,256
