hp@hp-HP-15-Notebook-PC:~$ sudo apt-get install curl
sudo: /var/lib/sudo/hp writable by non-owner (040777), should be mode 0700
[sudo] password for hp:
Reading package lists... Done
Building dependency tree
 curl : Depends: libcurl3 (= 7.35.0-1ubuntu2) but 7.37.1-1ubuntu3 is to be installed
hp@hp-HP-15-Notebook-PC:~$ curl
The program 'curl' is currently not installed. You can install it by typing:
hp@hp-HP-15-Notebook-PC:~$ sudo apt-get install aptitude
I am getting different error
dessert
  • 40,956
