I tried apt-get update and upgrade together and this is what I got.
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
What should I do?
What should I do?
Have you tried using sudo?
Updating applications requires you to use administrative powers, which for security reasons are locked behind sudo.
Try using:
sudo apt-get update
and
sudo apt-get upgrade
and enter your password to upgrade your programs.
To run both apt-get update and apt-get upgrade you need superuser privilege. You can run these together as,
sudo apt-get update && sudo apt-get upgrade
And obviously you need to give your administrative password.
The command apt-get update and apt-get upgrade requires you to be a root.
You have to do this way:
sudo apt-get update
Then you are prompted to enter your password. Enter it and enjoy :)
You want to superuser privilege to run these... Then, you should be superuser.. To be Superuser.. you should add "Sudo" to these commands.
Try this...
sudo apt-get update
And if it is asking a password, Then, Give your Password And Hit the Enter button..
