I have a problem trying to install Geant4 on Linux system.
$ cmake ..
CMake Error at CMakeLists.txt:13 (find_package):
  By not providing "FindGeant4.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Geant4", but
  CMake did not find one.
  Could not find a package configuration file provided by "Geant4" with any
  of the following names:
    Geant4Config.cmake
    geant4-config.cmake
  Add the installation prefix of "Geant4" to CMAKE_PREFIX_PATH or set
  "Geant4_DIR" to a directory containing one of the above files.  If "Geant4"
  provides a separate development package or SDK, be sure it has been
  installed.
-- Configuring incomplete, errors occurred!
See also "/home/dell/Desktop/geant4/geant4.9.6/examples/basic/B1/build/CMakeFiles/CMakeOutput.log".
I tried:
apt-get install g++
But I get:
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Zanna
  • 72,312
HF FH
You just have to source the geant4.sh
In the bash shell, give the command:
source /path_to_geant4_install/bin/geant4.sh
And then do cmake
Zanna
  • 72,312
I was having a similar problem.
It may help to add these commands in .bashrc:
source /home/user/geant4-install directory/bin/geant4.sh
source /home/user/geant4-install directory/share/geant4-version number/geant4make/geant4make.sh
export G4WORKDIR=/home/user/g4work
Zanna
  • 72,312
