user@chrubuntu:~$ sudo apt-get install wine1.7
[sudo] password for user:
Reading package lists... Done
Building dependency tree
wine1.7 : Depends: wine1.7-i386 (= 1:1.7.19-0ubuntu2~trusty2) but it is not installable
Recommends: gnome-exe-thumbnailer but it is not going to be installed or
kde-runtime but it is not going to be installed
Recommends: ttf-mscorefonts-installer but it is not going to be installed
Recommends: fonts-horai-umefont but it is not going to be installed
Recommends: fonts-unfonts-core but it is not going to be installed
Recommends: ttf-wqy-microhei
Recommends: winetricks but it is not going to be installed
user@chrubuntu:~$
Trying to install wine1.7 on Ubuntu 14.04 64 bit, and i'm not sure what this means, help is greatly appreciated. I already ran sudo apt-get update and get this:
W: Duplicate sources.list entry http://dl.google.com/linux/chrome/deb/ stable/main amd64 Packages (/var/lib/apt/lists/dl.google.com_linux_chrome_deb_dists_stable_main_binary-amd64_Packages)
W: You may want to run apt-get update to correct these problems
So I run apt-get update and:
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
This is all very stressing because I have been trying to get Wine for the past week and had to reinstall and IT STILL WON'T WORK.
