When I try to install loggerpro, this is the message I get. I looked on the forum and tried the following commands:
sudo apt-get install --reinstall deconf
and then it says: unable to access package deconf
then I tried
sudo apt-get install --reinstall debconf
and then i got
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-3.16.0-60-generic : Depends: linux-image-3.16.0-60-generic but it is not going to be installed
linux-image-extra-3.16.0-62-generic : Depends: linux-image-3.16.0-62-generic but it is not going to be installed
linux-image-generic-lts-utopic : Depends: linux-image-3.16.0-62-generic but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
then I try apt-get install:
XXXXX:~$ apt-get -f install
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
What do I do now? I'm not a computer person, so if you can explain what I should do next in the simplest terms possible I would really appreciate it!
OKay, I tried what john Orion suggested and this is what i got:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
account-plugin-windows-live libupstart1 linux-headers-3.16.0-30
linux-headers-3.16.0-30-generic linux-image-3.16.0-30-generic
linux-image-extra-3.16.0-30-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
linux-image-3.16.0-60-generic linux-image-3.16.0-62-generic
Suggested packages:
fdutils linux-lts-utopic-tools linux-headers-3.16.0-60-generic
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 195 not upgraded.
5 not fully installed or removed.
Need to get 0 B/31.0 MB of archives.
After this operation, 69.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 356758 files and directories currently installed.)
Preparing to unpack .../linux-image-3.16.0-62-generic_3.16.0-62.82~14.04.1_i386.deb ...
Done.
Unpacking linux-image-3.16.0-62-generic (3.16.0-62.82~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.16.0-62-generic_3.16.0-62.82~14.04.1_i386.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-3.16.0-62-generic' to '/boot/vmlinuz-3.16.0-62-generic.dpkg-new': failed to write (No space left on device)
No apport report written because the error message indicates a disk full error
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.16.0-62-generic /boot/vmlinuz-3.16.0-62-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.16.0-62-generic /boot/vmlinuz-3.16.0-62-generic
Preparing to unpack .../linux-image-3.16.0-60-generic_3.16.0-60.80~14.04.1_i386.deb ...
Done.
Unpacking linux-image-3.16.0-60-generic (3.16.0-60.80~14.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.16.0-60-generic_3.16.0-60.80~14.04.1_i386.deb (--unpack):
cannot copy extracted data for './boot/vmlinuz-3.16.0-60-generic' to '/boot/vmlinuz-3.16.0-60-generic.dpkg-new': failed to write (No space left on device)
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.16.0-60-generic /boot/vmlinuz-3.16.0-60-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.16.0-60-generic /boot/vmlinuz-3.16.0-60-generic
I still can't install new software, and get the same error message, and the dependency not satisfiable: vstdrivers.
Any other ideas?????
