I am new to Linux, can anyone be kind enough to help me know how to install software from the terminal?
I tried to install java by entering the command in the terminal
sudo apt-get install openjdk-7-jdk
but i get errors ,
E:Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E:Unable to lock the administration directory (/var/lib/dpkg/), are you root?
I also tried root
su -
but it says that the password is incorrect, so what is root ?
Advance Thanks for the help Guys.
By using sudo, you are temporarily becoming root for the duration of that command, just like you'd switched to root with su - root, executed the command, and switched back with exit.
Out of the box, Ubuntu doesn't configure a password for root, so you cannot log in as root directly like you're attempting to do with su. You either have to use sudo, or configure a password for the root user. It is recommended that you simply use sudo.
Are you sure you used sudo when trying to run the install command?
-1
You will get that error if you have the gui (graphic user interface) open. Check the desktop, is synaptic package manager open?
wlraider70
  • 1,683
