-1
E: Could not open lock file /var/lib/apt/lists/lock - open (13: Permission denied)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
How to proceed? I'm trying to install tor and I'm not able to run the command
apt-get update
I'm getting the above errors.
You need to run this command as the root user, or at least use sudo to grant you super user permissions.
Try:
sudo apt-get update
Hope that helps!
Arronical
  • 20,241
