I set up a new VPS instance of Ubuntu and am wondering what the easiest way is to get up and running with a basic LAMP stack (i.e. which packages are required, which configuration options need to be tweaked, if any, etc.).
sudo apt-get update
sudo apt-get install tasksel
sudo tasksel install lamp-server
It will install all the basic LAMP stack for you, prompt for MySQL root password, etc.
More specifically it will install the following packages, and their dependencies.
mysql-client-core-5.1 libwrap0 apache2
libaprutil1-dbd-sqlite3 tcpd
libapache2-mod-php5 apache2.2-common
apache2-utils php5-common
libaprutil1-ldap libaprutil1
php5-mysql mysql-server-core-5.1
libdbi-perl libplrpc-perl mysql-server
apache2.2-bin libdbd-mysql-perl
libhtml-template-perl
libnet-daemon-perl libapr1
mysql-server-5.1 libmysqlclient16
ssl-cert apache2-mpm-prefork
mysql-common mysql-client-5.1
You might also want to take a peek at the Ubuntu Server Guide.
- 6,873
Install Apache
sudo apt-get install apache2
Install PHP
sudo apt-get install php5 libapache2-mod-php5
As fo 16.04, the number is dropped:
sudo apt-get install php libapache2-mod-php
Install MySQL
sudo apt-get install mysql-server
Install phpMyAdmin
sudo apt-get install libapache2-mod-auth-mysql php5-mysql phpmyadmin
As with the PHP installation, in 16.04, the number is dropped:
sudo apt-get install libapache2-mod-auth-mysql php-mysql phpmyadmin
Combined installation
16.04:
sudo apt-get install apache2 php libapache2-mod-php mysql-server libapache2-mod-auth-mysql php-mysql phpmyadmin
Before 16.04:
sudo apt-get install apache2 php5 libapache2-mod-php5 mysql-server libapache2-mod-auth-mysql php5-mysql phpmyadmin
The easiest way to install LAMP with PHPMyAdmin is using:
sudo apt-get install lamp-server^ phpmyadmin
You don't even need to install taskel. More details can be found here, which gives this:
To access PHPMyAdmin, open terminal & type:
sudo -H gedit /etc/apache2/apache2.conf
Add this line somewhere in that file:
Include /etc/phpmyadmin/apache.conf
Finally restart Apache using:
/etc/init.d/apache2 restart
or
sudo service apache2 restart
- 72,312
- 401
- 4
- 3
In Synaptic, click edit and mark by task. Then select LAMP Server and hit apply. Done.
- 7,523
I personally always find that installing the MySQL server and then PHPMyAdmin will install all the parts I need
(doing this first means it asks for the root account password to be set in advance)
then
sudo apt-get install phpmyadmin
It also gives you all the tools you'll need to administrate your MySQL server once it's installed :)
- 17,455
- 365
On commandline the simplest way is probably to use tasksel:
- 19,191
- 32
- 112
- 191
- 29,406
The packages are apache2 and libapache2-mod-php5. php5 has a number of additional modules, you may need some. List them with apt-cache search php5
Try revising your search or
sudo apt-get install apache2 libapache2-mod-php5
Enable php5 with
sudo a2enmod php5
Restart apache
The following wiki pages can be very helpful if you are starting with apache.
https://help.ubuntu.com/community/ApacheMySQLPHP
https://help.ubuntu.com/11.10/serverguide/C/httpd.html
Note- This answer was migrated from elsewhere. To add mysql install
sudo apt-get install mysql-server php5-mysql
- 104,528
http://www.apachefriends.org/en/xampp-linux.html
It has LAMP as well as phpmyadmin integrated along with perl modules. Installs in /opt/lampp so can be installed/removed easily...
- 24,306
My Swiss Army knife command:
sudo apt-get install apache2 mysql-server mysql-client libapache2-mod-auth-mysql php5 php5-mysql libapache2-mod-php5 php5-mcrypt php5-curl php5-cli php5-gd phpmyadmin
- 207,228
- 1,519
PHP7.0 is standard on Ubuntu 16+
Heres the rundown:
1 As Always
sudo apt-get update
2 Install Apache2
3 Install mysql-server
4 Install PHP 7.0
sudo apt-get install php7.0 libapache2-mod-php7.0 php7.0-mysql php7.0-curl php-mbstring php7.0-mbstring php-gettext php7.0-json php-xml
sudo a2enmod php7.0
5 Install phpmyadmin
sudo apt-get install mcrypt
Note, you'll need to add Include /etc/phpmyadmin/apache.conf to the file you'll open with the following command. (credit)
sudo gedit /etc/apache2/apache2.conf
Optional
sudo a2enmod rewrite
- 1,866
Open terminal
Ctrl + Alt + T
Type
sudo apt install synaptic
This will install synaptic on your system
Type
sudo synaptic
to open it.
Go to search box
In the search field type apache and click on Search button
The following field appears
Scroll down to Apache2 and select the box left to it.
Click on apply
Select all dependencies and follow on screen instructions to install.
In a similar way install
php7.0 and mysql-server one by one
During installation of mysql-server system asks for root password. Provide it.
After everything is complete, close synaptic.
Now open your browser and in the address bar type localhost and press Enter
If the following page appears
then Apache2 installation is successfull
In terminal type
apt install vim
cd /var/www/html
vim testphp.php
Press
i
Type
<?php phpinfo(); ?>
Press
Esc : x Enter
Go to your browser and in the address bar type localhost/testphp.php
Then php7.0 installation is successfull
Go to terminal and type
mysql --version
If you get the following prompt (version numbers for you system may be different):
mysql Ver 14.14 Distrib 5.7.18, for Linux (x86_64) using EditLine wrapper
Then your mysql-server installation is successful.
Type
mysql -u root -p
You will get:
Enter password:
Give the password.
Then you are now successfully able to login
Type
mysql> quit
to logout.
Congratulations, you now have a full working LAMP Stack
Optional:
You can also install phpmyadmin using synaptic. During installation it will ask for default server to use. Select apache2. Follow other on screen instructions.
Then open your browser and in the address bar type localhost/phpmyadmin
The following page appears
In the username field type root and in the password field type the password for root user you have selected during mysql-server installation.
Click on Go button.
Now you have successfully installed phpmyadmin on your system.
- 4,136
You can install Bitnami lampstack.(Package containing all necessary sub packages of LAMP).
First of all create an account in bitnami website to download the bitnami-lampstack-5.5.30-1-linux-x64-installer.run file. Then copy the file to your desktop (for convenience ). To provide read and exicution permission, Open terminal (Ctrl + Alt + T). and type
chmod 755 chmod 755 'location of bitnami-lampstack-5.5.30-1-linux-x64-installer.run
Better drag and drop the .run file from your desktop after typing chmod 755, press enter.
Now double click on the .run file. It will guide you through the installation process.
Thank you.
I have a script for this task: lampi
Usage:
sudo lampi -i -s -n example.com.local -dr ~/example-site
What does it do:
- Install the LAMP stack (
-iflag) - Setup and configure apache2, mysql, php, phpmyadmin
- Then set up a custom site named example.com.local (
-noption) - Set ~/example-site directory as it's document root (
-droption) - Enable SSL (https) for this site (
-sflag)
Now, the site can be accessed with http://example.com.local or https://example.com.local
- 347
If you are on Ubuntu 16, it is simple with one command:
sudo apt-get install apache2 mysql-server php libapache2-mod-php php-mcrypt php-mysql phpmyadmin
And just follow the instruction on screen to enter password for mysql, phpmyadmin configuration
You can see more details on my blog http://tvivu.com/install-lamp-stack-ubuntu-16-04/
- 5,669
- 1
Follow All Steps
sudo apt-get update
sudo apt install php7.0-cli
sudo apt-get install phpmyadmin php-mbstring php-gettext
sudo phpenmod mcrypt
sudo phpenmod mbstring
sudo systemctl restart apache2
sudo apt-get update
(Note If phpmyadmin is not working after Than Try this last three line code)
gksu gedit /etc/apache2/apache2.conf
sudo apt-get install gksu^C
- 1,922
- 171
- 1
- 4
I have a made an easy to use, simple bash script that installs LAMP stack on your system automatically.
Just run this command in your terminal to use the bash script:
wget --no-cache -O - https://gist.github.com/EmpireWorld/737fbb9f403d4dd66dee1364d866ba7e/raw/install-lamp.sh | bash
Also phpMyAdmin installation included in the gist.
- 107
- 3
Try EHCP (easy hosting control panel) ...
ehcp installation on a clean server will do the dirty job for you ...
