.: is actually just . ( since : is the keyword that separates multiple paths ) which means the current folder the script is being executed in is included as part of the include_path. That way when you have two files in the same directory:
index.php
include-me.php
You can include the second in PHP with include('include-me.php');. Without . being in path you wouldn't be able to do so.
So in order to complete the install as mentioned you would need to either put the contents of /library in the same folder the script you are working on is in - or in /php/includes (Granted you remove the ; from the ini file). You can also create another directory - like /opt/Zend/library and add /opt/Zend/library to your include path statement: include_path = ".:/php/includes:/opt/Zend/library"
Lastly - since you are running Ubuntu it is recommended that you use Ubuntu's LAMP setup instead (Most all documentation assumes you are using). This can be installed by removing XAMPP and performing sudo tasksel install lamp-server which will install Apache 2.2, MySQL, PHP 5.3 onto the system. As covered in What's the easiest way to set up a LAMP stack?
