-1
ORIGINAL POST
This I would imagine is going to be a simple answer. I have Apache2 running on my Ubuntu server but it seems PHP is not installed. When I try to load a php page it does not load properly.
Example: http://urbanturtles.servegame.com/ (My Site)
At first I thought the php module was simply not loaded but when I try to run sudo a2enmod php but it did not work and I get this error: ERROR: Module php does not exist!
Thanks for help in advance!
EDIT
After trying to load a simple PHP page to show the php version I have gotten a new error trying to load the page. that error is visible here: http://urbanturtles.servegame.com/version.php . This makes me think I have more of an Apache issue than a php issue. I have a main Apahce sever that proxys all incoming traffic to each server inside my network. The Apache config for the main server looks like this:
<VirtualHost *:*>
        ServerName MaxKulik.net
        ServerAdmin max@maxkulik.net
        ProxyPreserveHost On
        ServerName "www.MaxKulik.net"
        ServerAlias "MaxKulik.net"
        ProxyPass / http://192.168.1.5/
        ProxyPassReverse / http://192.168.1.5/
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
<VirtualHost *:*>
        SSLProxyEngine On
        SSLProxyCheckPeerCN on
        SSLProxyCheckPeerExpire on
        ProxyPass / https://192.168.1.5/
        ProxyPassReverse / https://192.168.1.5.
</VirtualHost>
<VirtualHost *:*>
        ServerName USI
        ServerName "www.UrbanTurtles.servegame.com"
        ServerAlias "UrbanTurtles.servegame.com"
        ProxyPass / http://192.168.1.28
        ProxyPassReverse / http://192.168.1.28
</VirtualHost>
Max Kulik
  • 538
from viewing your site's page source, it shows that it loaded wp-blog-header.php from your wordpress installation. if you still thinks something wrong with your php, do as follows
  1. Create a text file, e.g. using notepad or any other text editor:
    <?php
    phpinfo();
  2. Save the file as "version.php". Make sure, that the extension is .php (not .txt)
  3. Upload the file to the root of your web server
  4. Open the file in your web browser, e.g. http://www.yourdomain.com/version.php
or you can install xampp or lampp as it comes with everything you need bundled
Vishwa
  • 165
