Possible Duplicate:
What’s the easiest way to set up a LAMP stack?
I am wordpress theme and website developer. back in windows i use WAMP server to access and develop themes in wordpress now in ubuntu the process is heavy. I mean i have to install apache, php, mysql and have to create databases using terminal (in windows i can do this by using wamp user interface and deploying is also very simple). so please help me to choose the best server for wordpress.
and finally are there any server like wamp in ubuntu?
i am using ubuntu 12.10 desktop 32bit version!
VENKI
  • 588
Firstly the Linux equivalent of WAMP is LAMP (though its more accurate the other way :) ) Unlike in windows most server software in Linux doesn't have GUIs by default; this is true for LAMP. To install make sure you have tasksel installed. at a terminal run:
sudo apt-get install tasksel
Once complete then run sudo tasksel install lamp-server.
This will create the folder www in /var/, so you should see it in /var/www this will be your web root. (For 14.04 and above, it would /var/www/html.)
You can now unzip wordpress into that folder. Once complete, in a web browser go to localhost/wordpress (In your URL using Firefox/Chrome for example type localhost/wordpress, this will lead you to your wordpress installer) and follow the instructions there. If you want a GUI for database management I've always used phpmyadmin. To install it run:
sudo apt-get install phpmyadmin
then in a browser go to http://localhost/phpmyadmin (As mentioned above, use the URL in your browser to go to http://localhost/phpmyadmin)
Note that if you're running this server remotely then replace localhost with the remote IP you can have access to.
muru
  • 207,228
David
  • 457
I used bitnami open source server.
Installation:
  1. Download bitnami with wordpress from the Bitnami site
  2. Before Installing:
    First, move the bintami.Run file to your Home folder. This is just precautionary. Second, Right-click on the file and select Properties. Under the Permissions tab, tick the checkbox near the bottom labelled Allow executing file as program. Click Apply Permissions. Then Close the Properties Window.
  3. install the bitnami following these instructions
muru
  • 207,228
VENKI
  • 588
Suggest you have a good look into juju - see here. See also Jorge's blog at this page. This is so cool ....
juju deploy wordpress
juju deploy mysql
juju add-relation wordpress mysql
