I'm using Ubuntu 12.04.3 on an AWS EC2 instance. This is my first time with an EC2 so it's all new to me. I'm also not the most experienced Linux guy either, so I apologize if this is a stupid question.
I want to install a LAMP stack on my EC2 instance which I'm following this tutorial. However, the very first step is to install Yum. I made sure to enable SSH, HTTP and HTTPS in my security groups.
First I typed
sudo yum update -y
It didn't like that and responded with "sudo: yum: command not found"
I then just did
yum update -y
It responded with"
The program 'yum' is currently not installed.  You can install it by typing:  apt-get install yum".
So after typing that to install yum I get the following messages
Err http://us-west-2.ec2.archive.ubuntu.com/ubuntu/ precise-updates/main libnss3 amd64 3.14.3-0ubuntu0.12.04.1
  403  Forbidden
Err http://security.ubuntu.com/ubuntu/ precise-security/main libnss3 amd64 3.14.3-0ubuntu0.12.04.1
  404  Not Found [IP: 91.189.92.202 80]
Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/n/nss/libnss3_3.14.3-0ubuntu0.12.04.1_amd64.deb  404  Not Found [IP: 91.189.92.202 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Considering this is the official tutorial through AWS, I'm not quite sure where to turn. I'd appreciate some advice/help.
Seth
  • 59,332
Ubuntu is based on Debian, which uses apt not yum which is what Red Hat uses. The Debian equivalent of:
yum update -y
Would be:
sudo apt-get update
As for your results when running apt-get install yum
403  Forbidden
Would seem to indicate you don't have access to that file (I get the same forbidden error myself).
apt-get update should resolve your 404 errors, which are probably just caused by an unsynced or outdated package index.
I'm not entirely sure how Amazon operates their EC2 servers, but you should be able to install a LAMP stack withtaskel see: What's the easiest way to set up a LAMP stack?
Seth
  • 59,332
To resolve the "forbidden" errors use:
sudo apt-get install yum
instead of apt-get install yum
techraf
  • 3,316
Problem
I did mistake to run yum or yum update or yum install git to normal window command prompt.
Solution
To connect to instance to perform a quick update type in the instance terminal sudo yum update -y
To install git in your/my EC2 instance install git in the instance terminal sudo yum install git -y
Agent
  • 101
For me it was just because I was not running this command from the /usr/bin folder where yum is located. For some reason the /usr/bin was not in the path variable.
amc
  • 7,292
MikeL
  • 181
