64
I have a system with a NVIDIA card that has a compute support of 3.5+ compared on https://developer.nvidia.com/cuda-gpus. How do I install CUDA and the NVIDIA drivers in Ubuntu without downloading the .deb files from NVIDIA?
Tim
  • 33,500
Terrance
  • 43,712
5 Answers5
96
Ubuntu 18.04, CUDA 10.1, libcudnn 7.5.1 and NVIDIA 418.67 drivers
Notes
  • 2021-01-07: Please use the 20.04 installation below moving forward as the steps are the same for both 18.04 and 20.04.
  • 2019-06-23: Recent updates with either the CUDA 10.0 or 10.1 versions the NVIDIA 418.67 driver, that installs with it, no longer has the 32bit libraries included and this will cause Steam and most games to no longer work. The version of libnvidia-gl-418:i386 only installs the 418.56 version which will not work with the 418.67 driver. Hopefully NVIDIA will release an update for that soon. I have added the info at the bottom of this answer in the .run file install part of how to download just the run file for the CUDA installer then you can use whatever driver you want. The run file is 2.3GB in size, so it might take a bit to download.
  • CUDA 9.x is not available through NVIDIA's ubuntu1804 repo. I did however write an answer for CUDA 9.2 at https://askubuntu.com/a/1086993/231142
Installing CUDA through the repository (instead of the .deb installation)
The following lines you can copy and paste to a terminal window. Press Ctrl+Alt+T to open a terminal window.
Remove and update
Remove any CUDA PPAs that may be setup and also remove the nvidia-cuda-toolkit if installed:
sudo rm /etc/apt/sources.list.d/cuda*
sudo apt remove --autoremove nvidia-cuda-toolkit
Recommended to also remove all NVIDIA drivers before installing new drivers:
sudo apt remove --autoremove nvidia-*
Then update the system:
sudo apt update
Add and install
Recently, I just found out that the CUDA installation works with the graphics-drivers ppa so if you don't have it added, add it now:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
The install the NVIDIA driver. For this we are going to use the 440 driver
sudo apt install nvidia-driver-440
Now, install the key:
sudo apt-key adv --fetch-keys  http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
Add the repos:
sudo bash -c 'echo "deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda.list'
sudo bash -c 'echo "deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda_learn.list'
Update the system again:
sudo apt update
Install CUDA 10.1:
sudo apt install cuda-10-1
It should be installing the NVIDIA 418.40 drivers with it as those are what are listed in the repo. See: http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/
Install libcudnn7 7.5.1:
sudo apt install libcudnn7
Tune environment and reboot
Add the following lines to your ~/.profile file for CUDA 10.1
# set PATH for cuda 10.1 installation
if [ -d "/usr/local/cuda-10.1/bin/" ]; then
    export PATH=/usr/local/cuda-10.1/bin${PATH:+:${PATH}}
    export LD_LIBRARY_PATH=/usr/local/cuda-10.1/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
fi
Reboot your computer.
Check your settings
Check NVIDIA Cuda Compiler with nvcc --version:
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Apr_24_19:10:27_PDT_2019
Cuda compilation tools, release 10.1, V10.1.168
Check libcudnn version /sbin/ldconfig -N -v $(sed 's/:/ /' <<< $LD_LIBRARY_PATH) 2>/dev/null | grep libcudnn:
terrance@terrance-ubuntu:~$ /sbin/ldconfig -N -v $(sed 's/:/ /' <<< $LD_LIBRARY_PATH) 2>/dev/null | grep libcudnn
    libcudnn.so.7 -> libcudnn.so.7.5.1
Check NVIDIA driver with nvidia-smi:
terrance@terrance-ubuntu:~$ nvidia-smi
Wed Jan 29 12:41:02 2020
| NVIDIA-SMI 440.48.02    Driver Version: 440.48.02    CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 750 Ti  Off  | 00000000:02:00.0  On |                  N/A |
| 40%   34C    P0     1W /  38W |    163MiB /  2000MiB |      1%      Default |
+-----------------------------------------------------------------------------+ | Processes: GPU Memory | | GPU PID Type Process name Usage | |=============================================================================| | 0 1993 G /usr/lib/xorg/Xorg 158MiB | | 0 2502 G compton 1MiB | +-----------------------------------------------------------------------------+
.run file install
Install driver
By using the sudo add-apt-repository ppa:graphics-drivers/ppa you can install the 430.26 newest driver or any that suit your fancy.
Install libcudnn7
Add the Repo:
Install the key:
Update the system:
sudo apt update
Install libcudnn7.5.1:
Download the .run file
Now download the cuda_10.1.105_418.39_linux.run from https://developer.nvidia.com/cuda-10.1-download-archive-base?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1804&target_type=runfilelocal
If you want CUDA 10.2 the download instructions are here: https://developer.nvidia.com/cuda-downloads?target_os=Linux&target_arch=x86_64&target_distro=Ubuntu&target_version=1804&target_type=runfilelocal Then follow through with the same steps as below but make sure to update to 10.2 instead of 10.1.
Then run the installer:
sudo sh cuda_10.1.105_418.39_linux.run
Type in accept and press enter on this screen:
│  End User License Agreement                                                  │
│  Preface        │
│  The Software License Agreement in Chapter 1 and the Supplement              │
│  in Chapter 2 contain license terms and conditions that govern               │
│  the use of NVIDIA software. By accepting this agreement, you                │
│  agree to comply with all the terms and conditions applicable                │
│  to the product(s) included herein.                                          │
│  NVIDIA Driver                                                               │
│  Description        │
│  This package contains the operating system driver and                       │
│ Do you accept the above EULA? (accept/decline/quit):                         │
│ accept
Unselect the driver and then choose Install by using the arrow keys and space bar to move and select or unselect:
│ CUDA Installer                                                               │
│ - [ ] Driver        │
│      [ ] 418.39                                                              │
│ + [X] CUDA Toolkit 10.1                                                      │
│   [X] CUDA Samples 10.1                                                      │
│   [X] CUDA Demo Suite 10.1                                                   │
│   [X] CUDA Documentation 10.1                                                │
│   Install        │
│   Options        │
│ Up/Down: Move | Left/Right: Expand | 'Enter': Select | 'A': Advanced options │
Wait for the install to finish, it might say errors during, but not to worry.
fi
Reboot the system for the changes to take effect.
Terrance
  • 43,712
20
Ubuntu 20.04 LTS, CUDA 11.5.0, NVIDIA 495 and libcudnn 8.0.4
I don't recommend installing the NVIDIA drivers that come with CUDA as they do not contain the dkms drivers that carry over into new kernel upgrades.
The Ubuntu repositories now contain the same drivers as the graphics-drivers PPA. So feel free to install the 495.44 drivers.
sudo apt install nvidia-driver-495
Reboot the system so the new driver takes effect.
Now, download the CUDA 11.5.0 .run file from NVIDIA:
wget https://developer.download.nvidia.com/compute/cuda/11.5.0/local_installers/cuda_11.5.0_495.29.05_linux.run
Run the .run file as sudo:
sudo sh ./cuda_11.5.0_495.29.05_linux.run
If you get the following, just choose Continue:
│ Existing package manager installation of the driver found. It is strongly    │
│ recommended that you remove this before continuing.                          │
│ Abort        │
│ Continue        │
Accept the EULA:
│  NVIDIA Software License Agreement and CUDA Supplement to                    │
│  Software License Agreement. Last updated: October 8, 2021                   │
│  The CUDA Toolkit End User License Agreement applies to the                  │
│  NVIDIA CUDA Toolkit, the NVIDIA CUDA Samples, the NVIDIA                    │
│  Display Driver, NVIDIA Nsight tools (Visual Studio Edition),                │
│  and the associated documentation on CUDA APIs, programming                  │
│  model and development tools. If you do not agree with the                   │
│  terms and conditions of the license agreement, then do not                  │
│  download or use the software.                                               │
│  Last updated: October 8, 2021.                                              │
│  Preface        │
│ accept
Unselect the video driver by pressing the spacebar while [X] Driver is highlighted:
│ CUDA Installer                                                               │
│ - [ ] Driver        │
│      [ ] 495.29.05                                                           │
│ + [X] CUDA Toolkit 11.5                                                      │
│   [X] CUDA Samples 11.5                                                      │
│   [X] CUDA Demo Suite 11.5                                                   │
│   [X] CUDA Documentation 11.5                                                │
│   Options        │
│   Install        │
Then press the down arrow to Install. Press Enter then wait for installation to complete.
After the installation is complete add the following to the bottom of your ~/.profile or add it to the /etc/profile.d/cuda.sh file which you might have to create for all users (global):
# set PATH for cuda 11.5 installation
if [ -d "/usr/local/cuda-11.5/bin/" ]; then
    export PATH=/usr/local/cuda-11.5/bin${PATH:+:${PATH}}
    export LD_LIBRARY_PATH=/usr/local/cuda-11.5/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
fi
Install libcudnn8
Add the Repo:
NOTE: The 20.04 repo from NVIDIA does not supply libcudnn but the 18.04 repo does and installs just fine into 20.04.
echo "deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /" | sudo tee /etc/apt/sources.list.d/cuda_learn.list
Install the key:
Update the system:
sudo apt update
Install libcudnn 8.0.4:
sudo apt install libcudnn8
I recommend now to reboot the system for the changes to take effect.
After it reboots check the installations:
~$ nvidia-smi
Thu Nov 18 07:31:31 2021
| NVIDIA-SMI 495.44       Driver Version: 495.44       CUDA Version: 11.5     |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0  On |                  N/A |
| 40%   38C    P8     1W /  38W |    310MiB /  2000MiB |      4%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 2091 G /usr/lib/xorg/Xorg 46MiB | | 0 N/A N/A 2680 G /usr/lib/xorg/Xorg 163MiB | | 0 N/A N/A 2906 G compton 1MiB | | 0 N/A N/A 3262 G /opt/waterfox/waterfox 85MiB | +-----------------------------------------------------------------------------+
and check CUDA install:
~$ nvcc -V
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Mon_Sep_13_19:13:29_PDT_2021
Cuda compilation tools, release 11.5, V11.5.50
Build cuda_11.5.r11.5/compiler.30411180_0
and check libcudnn install:
    libcudnn_cnn_infer.so.8 -> libcudnn_cnn_infer.so.8.0.4
    libcudnn.so.8 -> libcudnn.so.8.0.4
    libcudnn_adv_train.so.8 -> libcudnn_adv_train.so.8.0.4
    libcudnn_ops_infer.so.8 -> libcudnn_ops_infer.so.8.0.4
    libcudnn_cnn_train.so.8 -> libcudnn_cnn_train.so.8.0.4
    libcudnn_adv_infer.so.8 -> libcudnn_adv_infer.so.8.0.4
    libcudnn_ops_train.so.8 -> libcudnn_ops_train.so.8.0.4
Terrance
  • 43,712
22.04 LTS instructions that worked for me:
Install nvidia driver:
sudo apt install nvidia-utils-525  # change version number to the new one...
sudo apt install nvidia-driver-525
sudo shutdown -r now # restart
sudo apt autoremove # just for good measure, clean up
nvidia-smi # check that the system can find the driver and list the gpus
nvidia-settings  # to check current usage, etc.
Install Cuda without uninstalling the nvidia driver you just chose:
Find the cuda version you need: developer.nvidia.com/cuda-downloads
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/cuda-keyring_1.1-1_all.deb
sudo dpkg -i cuda-keyring_1.1-1_all.deb
sudo apt-get update
sudo apt-get -y install cuda
For me, this was the only way to get both the nvidia driver I wanted, and the version of cuda that i wanted while still being able to use nvidia-smi and nvidia-settings. If I installed nvidia-cuda-toolkit instead, it would uninstall the utils and driver that I selected and disable nvidia-smi.
Brian D
  • 378
I just want to add an alternative solution that ends up being much easier and modular, IMHO: use Nvidia's CUDA docker images!
This does require a working (proprietary) driver on the host machine, which can be installed from Ubuntu repos (nvidia-driver-470 is the final supported driver version for CUDA compute 3.5).
  1. sudo apt install nvidia-driver-470
  2. Install Docker and nvidia-docker2. See this guide from Nvidia; if you're running Ubuntu 21+ you'll want to replace $distribution with ubuntu2004 in this step.
  3. Find the CUDA docker image you want on Nvidia's DockerHub page; for example, if you want CUDA 11.4.2 and cuDNN 8 you could run
    $ docker pull nvidia/cuda:11.4.2-cudnn8-devel-ubuntu20.04
  4. Now run a container from that image, attaching your GPUs:
    $ docker run -it --rm --gpus all nvidia/cuda:11.4.2-cudnn8-devel-ubuntu20.04
    You should verify the container can see your GPU by running nvidia-smi, which will show the same output you get from running nvidia-smi NOT inside of Docker.
For anyone working with AWS deep learning base AMI:
The image comes with several NVIDIA CUDA environments built-in and by default works with one of them (in my case 10), but you can switch to any other, simply by changing the symlink:
$ sudo rm /usr/local/cuda
$ sudo ln -s /usr/local/cuda-10.2 /usr/local/cuda
More info:
https://docs.aws.amazon.com/dlami/latest/devguide/tutorial-base.html
MikeL
  • 181
