-1
After following all the instructions in CUDA Toolkit 11.7 Downloads, the last instruction
sudo apt-get -y install cuda
doesn't work for me.
Terminal shows this message:
dmitriy@dmitriy:~/git/drake$ sudo apt-get -y install cuda
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: cuda : Depends: cuda-11-7 (>= 11.7.0) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
PS: I have an NVIDIA Geforce 920MX card in my computer.
I try this: How do I resolve unmet dependencies after adding a PPA? (14 answers)
And I got this after this command sudo apt-get -u dist-upgrade, but I have the same error:
dmitriy@dmitriy:/var$ sudo apt-get -u dist-upgrade
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.15.0-41-generic
Found initrd image: /boot/initrd.img-5.15.0-41-generic
Found linux image: /boot/vmlinuz-5.13.0-52-generic
Found initrd image: /boot/initrd.img-5.13.0-52-generic
Found linux image: /boot/vmlinuz-5.13.0-51-generic
Found initrd image: /boot/initrd.img-5.13.0-51-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
Found Windows 10 on /dev/sda1
done
output of sudo apt update:
dmitriy@dmitriy:/var$ sudo apt update
Get:1 file:/var/cuda-repo-ubuntu2004-11-7-local  InRelease [1575 B]
Hit:2 http://ru.archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://ru.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:4 https://dl.google.com/linux/chrome/deb stable InRelease
Get:5 http://ru.archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Hit:6 http://ppa.launchpad.net/deadsnakes/ppa/ubuntu focal InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:8 http://security.ubuntu.com/ubuntu focal-security InRelease
Get:9 http://packages.microsoft.com/repos/code stable InRelease [10.4 kB]
Hit:10 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu focal InRelease
Get:11 https://repo.protonvpn.com/debian stable InRelease [2519 B]
Hit:12 https://download.docker.com/linux/ubuntu focal InRelease
Hit:13 http://ppa.launchpad.net/mkusb/ppa/ubuntu focal InRelease
Hit:14 https://deb.nodesource.com/node_18.x focal InRelease
Fetched 121 kB in 2s (72.7 kB/s)
All packages are up to date.
and output of sudo apt upgrade:
dmitriy@dmitriy:/var$ sudo apt upgrade
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  linux-headers-5.13.0-51-generic linux-hwe-5.13-headers-5.13.0-51
  linux-image-5.13.0-51-generic linux-modules-5.13.0-51-generic
  linux-modules-extra-5.13.0-51-generic
  linux-modules-nvidia-470-5.13.0-51-generic
  linux-objects-nvidia-470-5.13.0-51-generic
  linux-signatures-nvidia-5.13.0-51-generic
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
This didn't help:
Unable to correct problems, you have held broken packages (15 answers) Any solution please?
Any suggestion please?
Installing Aptitude is not a direct answer, but between apt, apt-get and synaptic, fixing dependency hell is quite difficult; aptitude is actually more user-friendly at it.
-1
aptitude
Install aptitude
sudo apt-get install aptitude
Install main package
sudo aptitude install cuda
