I followed this link here to download tensorflow with gpu support on my Ubuntu 20.04 OS. Here is a snapshot of my .bashrc that I suspect may be the problem but I cannot verify this.
# >>> conda initialize >>>
# !! Contents within this block are managed by 'conda init' !!
__conda_setup="$('/home/weiss/anaconda3/bin/conda' 'shell.bash' 'hook' 2> /dev/null)"
if [ $? -eq 0 ]; then
    eval "$__conda_setup"
else
    if [ -f "/home/weiss/anaconda3/etc/profile.d/conda.sh" ]; then
        . "/home/weiss/anaconda3/etc/profile.d/conda.sh"
    else
        export PATH="/home/weiss/anaconda3/bin:$PATH"
    fi
fi
unset __conda_setup
# <<< conda initialize <<<
export LD_LIBRARY_PATH=/usr/lib/cuda/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/lib/cuda/include:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/local/cuda-11.0/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH export PATH=/usr/local/cuda-11.0/bin${PATH:+:${PATH}} export LD_LIBRARY_PATH=/usr/local/cuda-11.0/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/local/cuda-11.0/include:$LD_LIBRARY_PATH echo 'export LD_LIBRARY_PATH=/usr/lib/cuda/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc echo 'export LD_LIBRARY_PATH=/usr/lib/cuda/include:$LD_LIBRARY_PATH' >> ~/.bashrc
export LD_LIBRARY_PATH=/usr/lib/cuda/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/lib/cuda/include:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/lib/cuda/lib64:$LD_LIBRARY_PATH export LD_LIBRARY_PATH=/usr/lib/cuda/include:$LD_LIBRARY_PATH
When I run this command
 tf.config.list_physical_devices('GPU')
I get the following
2021-09-15 18:11:46.561864: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-09-15 18:11:46.564618: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'libcusolver.so.11'; dlerror: libcusolver.so.11: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/lib/cuda/include:/usr/lib/cuda/lib64:/usr/local/cuda-11.0/include:/usr/local/cuda-11.0/lib64:/usr/local/cuda/lib64:/usr/local/cuda-11.0/lib64:/usr/lib/cuda/include:/usr/lib/cuda/lib64:
2021-09-15 18:11:46.565065: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1835] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
I have tried a number of other potential setups but nothing works. Any help or suggestions is appreciated.
Here is also a snapshot of nvidia-smi
| NVIDIA-SMI 460.91.03    Driver Version: 460.91.03    CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce GTX 1070    Off  | 00000000:01:00.0  On |                  N/A |
|  0%   53C    P0    34W / 200W |   1175MiB /  8085MiB |      2%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 934 G /usr/lib/xorg/Xorg 198MiB | | 0 N/A N/A 1542 G /usr/lib/xorg/Xorg 515MiB | | 0 N/A N/A 1674 G /usr/bin/gnome-shell 227MiB | | 0 N/A N/A 2843 G /usr/lib/firefox/firefox 219MiB | +-----------------------------------------------------------------------------+
justanewb
  • 111
