So my NVIDIA driver is latest:
$ dpkg --list | grep libnvidia-gl
ii  libnvidia-gl-455:amd64                     455.32.00-0ubuntu1                    amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
But steam will not launch. Allegedly, this is because it is missing 32 bit libraries.
When I try to install the 32 bit GL library, I get:
$ sudo apt-get install  libnvidia-gl-455:i386
Reading package lists... Done
Building dependency tree
Package libnvidia-gl-455:i386 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libnvidia-common-455
E: Package 'libnvidia-gl-455:i386' has no installation candidate
And following the prompted solution:
$ sudo apt-get install  libnvidia-common-455:i386
E: Unable to locate package libnvidia-common-455:i386
So, how can I get the 32 bit version of libGL for nvidia?
NOTE: I cannot downgrade my nvidia-driver to an earlier version, as CUDA requires latest, and my development uses CUDA.
Bram
  • 3,699
This is a common problem. The best solution I found so far is this post: Installing 32-bit libnvidia-gl alongside 64-bit version The main point to install 32 bit manually by using a run file from Nvidia. This way you can have both 64 and 32 bits on your machine.
