I do not know how to fix the following, and it's causing a huge delay on my progress on a research project:
(base) chaztikov@priority:~/git/modulus$ sudo apt-get install libc6-dev
Reading package lists... Done
Building dependency tree... Done
libc6-dev : Depends: libc6 (= 2.35-0ubuntu3) but 2.35-0ubuntu3.1 is to be installed
Edit 1: Thanks for your comments so far, I apologize for the readability of the following
(base) chaztikov@priority:~/git/modulus$ sudo apt install libc6=2.31-0ubuntu9.2 libc-bin=2.31-0ubuntu9.2
Package libc6 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
libc6:i386 libdb1-compat libnss-nisplus:i386 libnss-nis:i386 libcrypt1:i386
libnss-nisplus libnss-nis libcrypt1
Package libc-bin is a virtual package provided by:
libc-bin:i386 2.35-0ubuntu3 (= 2.35-0ubuntu3)
You should explicitly select one to install.
E: Version '2.31-0ubuntu9.2' for 'libc6' was not found
E: Version '2.31-0ubuntu9.2' for 'libc-bin' was not found
(base) chaztikov@priority:~/git/modulus$ sudo apt install libc-bin
libc-bin is already the newest version (2.35-0ubuntu3.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
(base) chaztikov@priority:~/git/modulus$ sudo aptitude install libc6
sudo: aptitude: command not found
(base) chaztikov@priority:~/git/modulus$ sudo apt-get aptitude
E: Invalid operation aptitude
(so at this point I installed aptitude-common)
libc6 is already the newest version (2.35-0ubuntu3.1).
libc6 is already installed at the requested version (2.35-0ubuntu3.1)
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
(base) chaztikov@priority:~/git/modulus$ sudo aptitude install libc6-bin
Couldn't find any package whose name or description matched "libc6-bin"
Unable to apply some actions, aborting
(base) chaztikov@priority:~/git/modulus$ sudo aptitude install libc-bin
libc-bin is already installed at the requested version (2.35-0ubuntu3.1)
At this point, I am not sure what I should do, my intuition is that it has something to do with virtual packages...?
Should I try to install using, for example, selections from https://pkgs.org/search/?q=libc-bin and https://pkgs.org/search/?q=libc6
