Steam and the majority of games on Linux rely on 32-bit OpenGL libraries being available. However, Nvidia planned to drop 32-bit support for CUDA for some time now. Luckily, the necessary 32-bit libraries can be manually installed to make Steam work.
I suggest you install both CUDA and the 64bit driver from the Nvidia repository first, then check what version of driver has been installed. Obviously, the 32-bit library files have to match the installed driver version. The appropriate files can be obtained by using the extract only option provided by the installer e.g. for 465.19.01 get the driver and do ./NVIDIA-Linux-x86_64-465.19.01.run -x
The i386 library files are in a folder named "32". To install the 32-bit library manually:
chmod u+x NVIDIA-Linux-x86_64-465.19.01.run
cd NVIDIA-Linux-x86_64-465.19.01
cd 32
sudo cp libEGL* libGLESv* libGLX* libnvidia-egl* libnvidia-gl* libnvidia-tls* /usr/lib32
There are some symlinks that should be created:
cd /usr/lib32
sudo ln -s libEGL_nvidia.so.465.19.01 libEGL_nvidia.so.0
sudo ln -s libGLESv1_CM_nvidia.so.465.19.01 libGLESv1_CM_nvidia.so.1
sudo ln -s libGLESv2_nvidia.so.465.19.01 libGLESv2_nvidia.so.2
sudo ln -s libGLX_nvidia.so.465.19.01 libGLX_indirect.so.0
sudo ln -s libGLX_nvidia.so.465.19.01 libGLX_nvidia.so.0
You will probably need to run this for the system to detect the new libraries:
sudo ldconfig
