I have installed Ubuntu desktop 18.04 on HP laptop with nVidia graphics card GM107GLM [Quadro M2000M]:
$ sudo lshw -C display
*-display
description: VGA compatible controller
product: GM107GLM [Quadro M2000M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:133 memory:e4000000-e4ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:3000(size=128) memory:e5080000-e50fffff
*-display
product: HD Graphics 530
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:131 memory:e3000000-e3ffffff memory:40000000-4fffffff ioport:6000(size=64) memory:c0000-dffff
I have installed nvidia-driver-460:
$ nvidia-smi
Sat May 22 16:03:23 2021
| NVIDIA-SMI 460.73.01    Driver Version: 460.73.01    CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Quadro M2000M       Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   33C    P8    N/A /  N/A |    716MiB /  4043MiB |      5%      Default |
|                               |                      |                  N/A |
+-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 2145 G /usr/lib/xorg/Xorg 551MiB | | 0 N/A N/A 2332 G /usr/bin/gnome-shell 33MiB | | 0 N/A N/A 2939 G ...AAAAAAAA== --shared-files 6MiB | | 0 N/A N/A 3456 G ...AAAAAAAAA= --shared-files 12MiB | | 0 N/A N/A 9540 G ...AAAAAAAAA= --shared-files 49MiB | | 0 N/A N/A 9843 G ...oken=17184766749938794993 8MiB | | 0 N/A N/A 9957 G /opt/zoom/zoom 5MiB | | 0 N/A N/A 10072 G ...AAAAAAAAA= --shared-files 34MiB | +-----------------------------------------------------------------------------+
I have been trying to install CUDA Toolkit 11.3, by following the the instructions in the link: CUDA 11.3 installation on Ubuntu 18.04:
$ wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/cuda-ubuntu1804.pin
$ sudo mv cuda-ubuntu1804.pin /etc/apt/preferences.d/cuda-repository-pin-600
$ wget https://developer.download.nvidia.com/compute/cuda/11.3.1/local_installers/cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
$ sudo dpkg -i cuda-repo-ubuntu1804-11-3-local_11.3.1-465.19.01-1_amd64.deb
$ sudo apt-key add /var/cuda-repo-ubuntu1804-11-3-local/7fa2af80.pub
$ sudo apt-get update
$ sudo apt-get -y install cuda
All commands succeeded, the last command failed as follows:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies. cuda : Depends: cuda-11-3 (>= 11.3.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
How can I fix this? Do I need to install some dependency? Or another version of CUDA?
Thanks
I had a similar problem on Ubuntu 20.04. At last I took these actions:
  • Clean all cuda*:
    sudo rm /etc/apt/sources.list.d/cuda*
    sudo apt remove --autoremove nvidia-cuda-toolkit
    sudo apt-get autoremove
    sudo apt-get autoclean
  • Then I used instructions from https://developer.nvidia.com/cuda-downloads, consecutively selecting the options:
    1. Linux
    2. x86_64
    3. Ubuntu
    4. 20.04 (or 18.04 in your case)
    5. The last choice is the Installer Type. The same as you, I tried deb (local), and runfile (local) and both failed. But with the option deb (network) I succeeded at last. You can easily find there set of commands, but may be more successful for you.
Andyrey
