System Information
- MSI Creator 15 Laptop
- NVIDIA GeForce RTX 2070 SUPER Mobile / Max-Q
- External LG Ultrawide monitor
- Windows 10 / Ubuntu 20.04 dual boot
The Problem
I have been using the nvidia 455 drivers on my Ubuntu 20.04 machine successfully now for about six months. I rarely use the Windows partition, but I was using it yesterday. After shutting down Windows 10 and returning to Ubuntu, my external display stopped working entirely.
(Note: it's possible Windows has nothing to do with the issue -- restarting may have given Ubuntu the chance to update packages and break itself)
Apparently, the NVIDIA drivers no longer work. Running nvidia-smi and other commands produced the following error:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Googling for answers, most of the solutions recommended reinstalling the NVIDIA drivers when this happens. Note that I need the graphics drivers as well as the CUDA toolkit along with nvcc etc..
Purge Nvidia
I have tried many different solutions, and I run these commands whenever I get stuck and need to start fresh.
sudo apt purge nvidia*
sudo apt purge libnvidia*
sudo apt autoremove
Normally I'm running these in recovery mode after freshly-installed drivers cause Ubuntu to get stuck in the startup process after rebooting.
I also check dpkg -l | grep nvidia and remove any of the packages left over by the installation process. This was necessary when I wanted to install older versions of the drivers.
Attempted Solutions
Here's a list of everything I've tried:
restarting my machine countless times (including full power off and unplugging for a while)
Following the official NVIDIA Cuda Installation Guide to reinstall drivers and manage conflicts. For example,
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/cuda-ubuntu2004.pin
sudo mv cuda-ubuntu2004.pin /etc/apt/preferences.d/cuda-repository-pin-600
wget https://developer.download.nvidia.com/compute/cuda/11.4.1/local_installers/cuda-repo-ubuntu2004-11-4-local_11.4.1-470.57.02-1_amd64.deb
sudo dpkg -i cuda-repo-ubuntu2004-11-4-local_11.4.1-470.57.02-1_amd64.deb
sudo apt-key add /var/cuda-repo-ubuntu2004-11-4-local/7fa2af80.pub
sudo apt-get update
sudo apt-get -y install cuda
- Tried to blacklist noveau and nvidiafb:
blacklist nvidiafb
blacklist nouveau
options nouveau modeset=0
When reinstalling nvidia drivers, I tried multiple driver versions (470, 465, 460, 455) using multiple installation methods (first deb, then ubuntu-distributed, then runfile). All of them failed in different ways. Most commonly, when I reboot after installing the drivers, Ubuntu hangs infinitely on startup (I see a black screen with an MSI logo and an "ubuntu" logo, sometimes with a spinning circle).
The NVIDIA drivers seem to still be working fine in Windows, so I don't think my graphics card is fried or anything like that.
booting into Ubuntu recovery mode from grub and select the dpkg repaiingr option -- didn't seem to help anything
sudo ubundu-drivers autoinstall-- this installed the nvidia 470 drivers, unsuccessfullyI noticed that
uname -rindicated my kernel version was 5.11, when the support table for the Nvidia drivers shows that only 5.4 is supported for Ubuntu 20.04. So, I downgraded o 5.4 and re-installed the nvidia drivers, again with no success.
Observations
nvidia-smi does produce output (instead of an error) in the following situations:
- after reinstalling drivers but before restarting the system
- in recovery mode after reinstalling drivers
What now?
I am at a complete loss for what to do. The only thing I can think of is to completely re-install Ubuntu, which seems crazy when everything was working just fine yesterday.
References
AskUbuntu.SE, "Blank screen after installing nvidia restricted driver"
AskUbuntu.SE, Ubuntu 18.04 and nVidia. Stuck after boot
AskUbuntu.SE, Boot hangs after installing the latest driver from PPA and Ctrl+Alt+F1 keyboard shortcut doesn't work
AskUbuntu.SE, Stuck at boot screen, Nvidia graphics driver issues
AskUbuntu.SE Changing NVIDIA Drivers makes Ubuntu freeze on startup
AskUbuntu.SE Blank screen after installing nvidia restricted driver
AskUbuntu.SE graphics driver stopped working
AskUbuntu.SE Ubuntu 20.04 Nvidia graphics unusable (recommends switching to kernel 5.4)
System Info
Before writing this question, I again purged everything from my system using the method described above. In this state, here is some system information:
Kernel Version
$ uname -r
5.4.0-80-generic
Secure Boot
$ sudo mokutil --sb-state
SecureBoot disabled
lshw
$ sudo lshw -C display
*-display UNCLAIMED
description: VGA compatible controller
product: TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller cap_list
configuration: latency=0
resources: memory:ac000000-acffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:3000(size=128) memory:ad000000-ad07ffff
*-display
product: UHD Graphics
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 05
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:191 memory:ab000000-abffffff memory:40000000-4fffffff ioport:4000(size=64) memory:c0000-dffff
hwinfo
$ hwinfo --gfxcard
16: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.pBgP2fGEzV8
Parent ID: vSkL.sXdMPV6yXb4
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "nVidia VGA compatible controller"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1e91
SubVendor: pci 0x1462 "Micro-Star International Co., Ltd. [MSI]"
SubDevice: pci 0x12c6
Revision: 0xa1
Memory Range: 0xac000000-0xacffffff (rw,non-prefetchable,disabled)
Memory Range: 0x80000000-0x8fffffff (ro,non-prefetchable,disabled)
Memory Range: 0x90000000-0x91ffffff (ro,non-prefetchable,disabled)
I/O Ports: 0x3000-0x307f (rw,disabled)
Memory Range: 0xad000000-0xad07ffff (ro,non-prefetchable,disabled)
IRQ: 255 (no events)
Module Alias: "pci:v000010DEd00001E91sv00001462sd000012C6bc03sc00i00"
Driver Info #0:
Driver Status: nvidiafb is not active
Driver Activation Cmd: "modprobe nvidiafb"
Driver Info #1:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #2:
Driver Status: nvidia_drm is not active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #3:
Driver Status: nvidia is not active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #11 (PCI bridge)
34: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.7YEiQ6GHkFE
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Onboard - Video"
Model: "Intel VGA compatible controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x9bc4
Revision: 0x05
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xab000000-0xabffffff (rw,non-prefetchable)
Memory Range: 0x40000000-0x4fffffff (ro,non-prefetchable)
I/O Ports: 0x4000-0x403f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 192 (55080 events)
Module Alias: "pci:v00008086d00009BC4sv00001462sd000012C6bc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Primary display adapter: #16
ubuntu-drivers
$ ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001E91sv00001462sd000012C6bc03sc00i00
vendor : NVIDIA Corporation
driver : nvidia-driver-450-server - distro non-free
driver : nvidia-driver-460 - distro non-free recommended
driver : nvidia-driver-470-server - distro non-free
driver : nvidia-driver-470 - third-party non-free
driver : nvidia-driver-460-server - distro non-free
driver : xserver-xorg-video-nouveau - distro free builtin
Thank You!
Please let me know if any further information is needed and I'll do my best to provide it! Thanks for any help you can provide!
