I am trying to set up CUDA on my new Ubuntu 22.04 machine and following the instructions as per, official Nvidia guide But I get this when I try to install any package after CUDA installation.
I tried running sudo apt --fix-broken install but got this error log.
atif@aihwkit:~$ uname -r
5.15.0-43-generic
atif@aihwkit:~$ sudo apt-get install linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree... Done
linux-headers-5.15.0-43-generic is already the newest version (5.15.0-43.46).
linux-headers-5.15.0-43-generic set to manually installed.
You might want to run 'apt --fix-broken install' to correct these.
cuda-drivers-515 : Depends: libnvidia-compute-515 (>= 515.48.07) but it is not going to be installed
Depends: nvidia-compute-utils-515 (>= 515.48.07) but it is not going to be installed
Depends: nvidia-kernel-common-515 (>= 515.48.07) but it is not going to be installed
Depends: nvidia-utils-515 (>= 515.48.07) but it is not going to be installed
libnvidia-decode-515 : Depends: libnvidia-compute-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
nvidia-dkms-515 : Depends: nvidia-kernel-common-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
nvidia-driver-515 : Depends: libnvidia-compute-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
Depends: libnvidia-extra-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
Depends: nvidia-compute-utils-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
Depends: nvidia-utils-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
Depends: libnvidia-cfg1-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
Recommends: libnvidia-compute-515:i386 (= 515.48.07-0ubuntu1)
Recommends: libnvidia-decode-515:i386 (= 515.48.07-0ubuntu1)
Recommends: libnvidia-encode-515:i386 (= 515.48.07-0ubuntu1)
Recommends: libnvidia-fbc1-515:i386 (= 515.48.07-0ubuntu1)
Recommends: libnvidia-gl-515:i386 (= 515.48.07-0ubuntu1)
xserver-xorg-video-nvidia-515 : Depends: libnvidia-cfg1-515 (= 515.48.07-0ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
atif@aihwkit:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
libnvidia-cfg1-515 libnvidia-compute-515 libnvidia-extra-515 nvidia-compute-utils-515
nvidia-kernel-common-515 nvidia-utils-515
The following NEW packages will be installed:
0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
208 not fully installed or removed.
Need to get 67.5 MB of archives.
After this operation, 236 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 libnvidia-compute-515 515.48.07-0ubuntu1 [45.0 MB]
Get:2 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 nvidia-compute-utils-515 515.48.07-0ubuntu1 [271 kB]
Get:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 nvidia-kernel-common-515 515.48.07-0ubuntu1 [21.7 MB]
Get:4 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 libnvidia-extra-515 515.48.07-0ubuntu1 [56.8 kB]
Get:5 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 nvidia-utils-515 515.48.07-0ubuntu1 [337 kB]
Get:6 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64 libnvidia-cfg1-515 515.48.07-0ubuntu1 [85.4 kB]
Fetched 67.5 MB in 3s (20.9 MB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 80853 files and directories currently installed.)
Preparing to unpack .../0-libnvidia-compute-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking libnvidia-compute-515:amd64 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/0-libnvidia-compute-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './usr/lib/x86_64-linux-gnu/libcuda.so.515.48.07' before installing new version: Invalid cross-device link
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../1-nvidia-compute-utils-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking nvidia-compute-utils-515 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/1-nvidia-compute-utils-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './usr/bin/nvidia-cuda-mps-control' before installing new version: Invalid cross-device link
Preparing to unpack .../2-nvidia-kernel-common-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking nvidia-kernel-common-515 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/2-nvidia-kernel-common-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './lib/firmware/nvidia/515.48.07/gsp.bin' before installing new version: Invalid cross-device link
Preparing to unpack .../3-libnvidia-extra-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking libnvidia-extra-515:amd64 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/3-libnvidia-extra-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.515.48.07' before installing new version: Invalid cross-device link
Preparing to unpack .../4-nvidia-utils-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking nvidia-utils-515 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/4-nvidia-utils-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './usr/bin/nvidia-debugdump' before installing new version: Invalid cross-device link
Preparing to unpack .../5-libnvidia-cfg1-515_515.48.07-0ubuntu1_amd64.deb ...
Unpacking libnvidia-cfg1-515:amd64 (515.48.07-0ubuntu1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-87d4eZ/5-libnvidia-cfg1-515_515.48.07-0ubuntu1_amd64.deb (--unpack):
unable to make backup link of './usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.515.48.07' before installing new version: Invalid cross-device link
