There was an update in my Ubuntu 22.04.03 LTS OS last week, and my nvidia-515 with cuda 11.7 broke. On reinstalling, it fails. I'm stuck, tried to debug and inspect logs - which points to version mismatch, but the versions are indeed the same 11.4.0.
Is it the name that needs some change. Forcing alias of cc and gcc to x86_64 also hasn't change anything. Tried multiple iterations with reboots after each attempt, to no avail. Sadly using "apt install nvidia-driver-515" is not an option because it install 525 due to its transition. Have a hard need for driver-515 with cuda 11.7.
$ sudo ./cuda_11.7.0_515.43.04_linux.run
[Error - listed in nvidia-installer.log below]
$ vim /var/log/nvidia-installer.log ... The kernel was built by: x86_64-linux-gnu-gcc-11 (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0 You are using: cc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
$ ll /usr/bin/gcc lrwxrwxrwx 1 root root 32 Aug 20 09:53 /usr/bin/gcc -> /usr/bin/x86_64-linux-gnu-gcc-11*
$ ll /usr/bin/cc lrwxrwxrwx 1 root root 20 Aug 20 09:16 /usr/bin/cc -> /etc/alternatives/cc*
$ ll /etc/alternatives/cc lrwxrwxrwx 1 root root 12 Aug 20 09:16 /etc/alternatives/cc -> /usr/bin/gcc*
$ gcc --version gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
$ x86_64-linux-gnu-gcc-11 --version x86_64-linux-gnu-gcc-11 (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 22.04.3 LTS Release: 22.04 Codename: jammy
Vishal Anand
  • 101
My cuda install recently broke after a system update, too. I'm on 22.04 had a hard need for nvidia-driver-535 and cuda toolkit 12.1. Perhaps this will work for you with driver-515 and 11.4.
I was getting the same compiler mismatch errors you saw, so I manually updated the symlink in /usr/bin/gcc from gcc-11 to gcc-12.
I removed and purged all nvidia drivers with
sudo apt remove --purge '^nvidia-.*'
and restarted to confirm there were no nvidia drivers in place.
Then I followed the instructions here:
How do I install NVIDIA and CUDA drivers into Ubuntu?
essentially:
  • apt install nvidia-driver-535
  • restart to confirm driver-535 was in place
  • ran the local runfile ignoring the runfile installer's warning and de-selecting the driver:
  • sudo ./cuda_12.1.1_530.30.02_linux.run
Currently, nvidia-smi, nvcc --version, and all the cuda-samples are Working as Designed. I hope this helps you, too.
smcnally
  • 470
