134
My overall upgrade went well, but I am left with a critically lingering issue of mysql-server not being able to install itself, and nothing I am trying gets it to work.
This is the error I see when trying to install/reinstall it:
Setting up mysql-server-5.7 (5.7.11-0ubuntu6) ...
Job for mysql.service failed because the control process exited with error code. See "systemctl status mysql.service" and "journalctl -xe" for details.
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.7 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.7; however:
  Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
                   Processing triggers for systemd (229-4ubuntu4) ...
Processing triggers for ureadahead (0.100.0-19) ...
 mysql-server-5.7
 mysql-server
I've tried completely removing it, though doing so attempts to install MariaDB because of dependencies (?). Any suggestions on what I can do to fix this would be most welcome.
EDIT: Looks like I'm not the only one: https://bugs.launchpad.net/ubuntu/+source/mysql-5.7/+bug/1573279
TheGremlyn
  • 2,774
10 Answers10
129
The instructions @andrew-beerman posted are on the right track, though they aren't quite clear to me and seem to recommend more than is necessary. I pieced together the answer from the above and a helpful post in the bug thread.
These are the steps I took to correct this:
  1. Back up your my.cnf file in /etc/mysql and remove or rename it
    sudo mv /etc/mysql/my.cnf /etc/mysql/my.cnf.bak
  2. Remove the folder /etc/mysql/mysql.conf.d/ using
    sudo rm -r /etc/mysql/mysql.conf.d/
  3. Verify you don't have a my.cnf file stashed somewhere else (I did in my home dir!) or in /etc/alternatives/my.cnf use
    sudo find / -name my.cnf
  4. Backup and remove /etc/mysql/debian.cnf files (not sure if needed, but just in case)
    sudo mv /etc/mysql/debian.cnf /etc/mysql/debian.cnf.bak
    sudo apt purge mysql-server mysql-server-5.7 mysql-server-core-5.7
    sudo apt install mysql-server
  5. In case your syslog shows an error like "mysqld: Can't read dir of '/etc/mysql/conf.d/'" create a symbolic link:
    sudo ln -s /etc/mysql/mysql.conf.d /etc/mysql/conf.d
    Then the service should be able to start with sudo service mysql start.
That got it working!
muru
  • 207,228
TheGremlyn
  • 2,774
63
Today I got the same problem, after trying many solutions i found that the problem was the command sudo systemctl disable mysql.service that i used to disable MySQL auto starting, so to get it working i re-enabled again MySQL server using the command sudo systemctl enable mysql.service and run again the upgrade process and it terminated perfectly.
21
Your error message contains this line:
However, this installed post-installation script is not mentioned by name. After much tinkering, I found out that its name is (in my case) /var/lib/dpkg/info/mysql-server-5.7.postinst.
Open this file with sudo vi /var/lib/dpkg/info/mysql-server-5.7.postinst, or your preferred editor.
At the top, change line 3 (or so): set -e to set -x, save the file. (option -e is "exit on errors", -x means "explicitly show command executed", presumably)
Run sudo dpkg --configure -a --log /tmp/dpkg.log (the --log option is optional). You can also simply run apt upgrade if you know it'll be the only package that will be upgraded.
Now you get verbose output of the mysql-server-5.7.postinst bash script, and you can figure out what's wrong.
In my case it unsuccessfully tried to (re-)run mysql_upgrade, but that was not needed for my customized mysql installation. I was sure I've run it manually before, successfully, and all was well.
So I commmented out line 321 (for older mysqld releases try line 281),
#mysql_upgrade --defaults-file=/etc/mysql/debian.cnf || result=$?
and the command that has failed before, sudo apt upgrade (run it again), finished successfully, and dpkg removed the error status for this package.
Now you can set back the set -x to set -e (mentioned above). And optionally uncomment the mysql-upgrade line.
Extra work might be required if you have moved your mysql data partition to a nonstandard location. I moved mine from /var/lib/mysql/data to a different drive via symlink. Then you might have to remove the symbolic link temporarily, before the postinst script manipulation. Then re-create it after running the package upgrade.
After the next minor version upgrade of the mysqld debian package, this problem with the /var/lib/dpkg/info/mysql-server-5.7.postinst script can show up again.
knb
  • 5,292
18
The instructions here fixed it on my server: https://bugs.mysql.com/bug.php?id=72722
I can understand the pain of having your system in inconsistent state but lets not worry about the whole situation and take it step by step to get the system clean.
First lets see the current state of all the mysql packages on machine using: dpkg -l | grep mysql (Please paste the output excluding last column)
The first column denotes the current status of the package. Here are the possible options:
ii) Installed rc) Removed config-files kept (This should be the state of all the packages you have removed with 'apt-get remove' that does not remove config-files under /etc)
For this to work, you will need to run 'apt-get purge <pkg-name>' till you do not see any packages in the above list.
Please remember that some non-mysql-server packages like python-mysql.connector and python-mysqldb, if installed, need not be removed as they do not have any affect on this situation but if removed might cause trouble to applications using them.
We will definitely try to re-visit our docs to see how can we safeguard users from getting into this trouble. Thanks for sharing your feedback in detail with us.
Toskan
  • 254
In my case, with strace, I saw that /var/run/mysqld/ didn't exist and mysqld can't create the file mysqld.sock.
These commands solved my problem:
mkdir /var/run/mysqld
chown mysql.mysql /var/run/mysqld
chmod 700 /var/run/mysqld
Now:
systemctl start mysql
And mysql works again :)
In my case I could solv the problem by adding
# Allow log file access
/home/system/var/log/mysql.err rw,
/home/system/var/log/mysql.log rw,
/home/system/var/log/mysql/ r,
/home/system/var/log/mysql/** rw,
to /etc/apparmor.d/local/usr.sbin.mysqld
For more details take a look at my answer (by ChristophS) at stackoverflow.
For WSl Ubuntu 16.04 version I found this helpful article here
Steps to follow to resolved
  1. sudo vi /var/lib/dpkg/info/mysql-server-5.7.postinst
  2. Look for this line mysql_upgrade --defaults-file=/etc/mysql/debian.cnf || result=$?
  3. Add this service mysql restart directly above line in number 2.
  4. Save and run this sudo dpkg --configure -a
it should look like
Hope this help
Fil
  • 153
I had the same issue. I tried to re-install mysql several times, but had no success.
I figured out that the problem for me was, that another mysql process was already running.
In details:
After I read carefully logs in /var/log/mysql/error.log, and found:
[ERROR] Can't start server: Bind on TCP/IP port: Address already in use
[ERROR] Do you already have another mysqld server running on port: 3306 ?
Looks like another application was using already the port.
I checked it using ps -aux | grep 3306:
$ ps -aux | grep 3306
milkovs+  6802  0.0  0.0  16336  1084 pts/19   S+   21:39   0:00 grep --color=auto 3306
mysql    14706  0.0  0.3 1270192 13916 pts/2   Sl   Aug19   0:29 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib/mysql/plugin --user=mysql --skip-grant-tables --log-error=/var/log/mysql/error.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/run/mysqld/mysqld.sock --port=3306 --log-syslog=1 --log-syslog-facility=daemon --log-syslog-tag=
And I killed the running process sudo kill -15 14706
Then I started mysql: /etc/init.d/mysql start
Finally mysql works for me! I hope it helps somebody.
milkovsky
  • 175
  • 14
I have had the issue on a few servers now The fix was to run apt install phpmyadmin --reinstall
which resolved the above (with no need to touch mysql afterwards)
Andy
  • 111
None of the answers on this page worked for me.
I ended up going to the Oracle downloads page, downloading mysql-apt-config_0.8.8-1_all.deb, and installing MySQL from Oracle repo:
sudo dpkg -i mysql-apt-config_0.8.8-1_all.deb
sudo apt update
ostrokach
  • 864
