I have issues installing mysql,
sudo apt-get update
sudo apt-get install mysql-server
I also tried:
sudo dpkg -P mysql-server-5.1 mysql-server
I get the following error:
Job for mysql.service failed because the control process exited with error code.
See "systemctl status mysql.service" and "journalctl -xe" for details.
invoke-rc.d: initscript mysql, action "start" failed.
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2017-05-15 14:43:06 CEST; 5ms ago
Process: 22585 ExecStartPost=/usr/share/mysql/mysql-systemd-start post (code=exited, status=0/SUCCESS)
Process: 22584 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 22576 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 22584 (code=exited, status=1/FAILURE)
CPU: 485ms
maj 15 14:43:06 XPS-13-9350 systemd[1]: mysql.service: Unit entered failed state.
maj 15 14:43:06 XPS-13-9350 systemd[1]: mysql.service: Failed with result 'exit-code'.
dpkg: error processing package mysql-server-5.7 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.7; however:
Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for systemd (232-21ubuntu3) ...
Processing triggers for ureadahead (0.100.0-19) ...
mysql-server-5.7
mysql-server
If I type mysql I get:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
It seems to have semi-installed as if I do mysql -u root -p I get the password prompt, but nothing happens.
I tried starting it using sudo service mysql start but I got this error message in mysql.service:
$ systemctl status mysql.service
Active: activating (start-post) (Result: exit-code) since Mon 2017-05-15 14:24:24 CEST; 13s ago
Process: 13333 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 13317 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 13333 (code=exited, status=1/FAILURE); Control PID: 13334 (mysql-systemd-s)
Tasks: 2 (limit: 4915)
Memory: 1.8M
CPU: 353ms
CGroup: /system.slice/mysql.service
└─control
├─13334 /bin/bash /usr/share/mysql/mysql-systemd-start post
└─13397 sleep 1
maj 15 14:24:24 XPS-13-9350 systemd[1]: Starting MySQL Community Server...
maj 15 14:24:26 XPS-13-9350 systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
