I tried to install a package, but there was some kind of problem with dependencies. First I tried to clean up everything with the command sudo apt-get autoremove and I got a similar error message as with apt-get install
Output after autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up apache2 (2.4.18-2ubuntu3.5) ...
info: Executing deferred 'a2enconf javascript-common' for package javascript-common
ERROR: Conf javascript-common does not exist!
dpkg: error processing package apache2 (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up mysql-common (5.7.20-0ubuntu0.16.04.1) ...
update-alternatives: error: alternative path /etc/mysql/my.cnf.fallback doesn't exist
dpkg: error processing package mysql-common (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of libmysqlclient20:amd64:
libmysqlclient20:amd64 depends on mysql-common (>= 5.5); however:
Package mysql-common is not configured yet.
dpkg: error processing package libmysqlclient20:amd64 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of mysql-client-5.7:
mysql-client-5.7 depends on mysql-common (>= 5.5); however:
dpkg: error processing package mysql-client-5.7 (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
apache2
mysql-common
mysql-client-5.7
Any solutions? Seems there is some problem with the packages apache2, mysql-common etc. but I got no idea since I'm not very experienced with the command line.
