I was running mysqld on 14.04 with a non-standard --datadir (/usr/local/mysqld-test) & port (33306). After upgrading to 16.04, I was no longer able to start up my test mysqld, so, following the instructions here and in the bug it links to here, I wound up going as far as:
sudo apt purge mariadb-client-10.0 mariadb-common mysql-client mysql-client-5.7 mysql-client-core-5.7 mysql-common dbconfig-mysql
sudo apt-get install mysql-client mysql-server
(In the process, it uninstalled amarok!? snarl)
That still wasn't working, so I wound up nuking my entire /usr/local/mysqld-test (intentionally; in theory I have scripts to rebuild it). The mysql_install_db command I had used before is deprecated now, and doesn't seem to understand the -P 33306 argument, so instead I'm trying to use mysqld --initialize-insecure.
Here's what I'm doing:
mysqld --initialize-insecure --basedir=/usr/local/mysqld-test --datadir=/usr/local/mysqld-test/data
It fails:
mysqld: Can't create directory '/usr/local/mysqld-test/data/' (Errcode: 13 - Permission denied)
2016-11-02T10:21:37.547443Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2016-11-02T10:21:37.549183Z 0 [ERROR] Aborting
Huh. I thought I made that world-writable:
$ ls -al /usr/local/mysqld-test
total 8
drwxrwxrwx 2 kuhrusty kuhrusty 4096 Nov 2 03:13 .
drwxr-xr-x 20 root root 4096 Nov 2 03:13 ..
WTF? Let's try that with strace:
execve("/usr/sbin/mysqld", ["mysqld", "--initialize-insecure", "--basedir=/usr/local/mysqld-test", "--datadir=/usr/local/mysqld-test"...], [/* 69 vars */]) = 0
It mmaps a bunch of shared libraries, sets some signal handlers, and then looks for config files (which I don't think I've messed with--I start it up manually, passing --datadir, -P, etc.):
stat("/etc/my.cnf", 0x7ffe13e99af0) = -1 ENOENT (No such file or directory)
stat("/etc/mysql/my.cnf", {st_mode=S_IFREG|0644, st_size=682, ...}) = 0
open("/etc/mysql/my.cnf", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=682, ...}) = 0
read(3, "#\n# The MySQL database server co"..., 4096) = 682
open("/etc/mysql/conf.d/", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
fstat(4, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
brk(0x271d000) = 0x271d000
getdents(4, /* 4 entries */, 32768) = 120
getdents(4, /* 0 entries */, 32768) = 0
close(4) = 0
stat("/etc/mysql/conf.d/mysql.cnf", {st_mode=S_IFREG|0644, st_size=8, ...}) = 0
open("/etc/mysql/conf.d/mysql.cnf", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=8, ...}) = 0
read(4, "[mysql]\n", 4096) = 8
read(4, "", 4096) = 0
close(4) = 0
stat("/etc/mysql/conf.d/mysqldump.cnf", {st_mode=S_IFREG|0644, st_size=55, ...}) = 0
open("/etc/mysql/conf.d/mysqldump.cnf", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=55, ...}) = 0
read(4, "[mysqldump]\nquick\nquote-names\nma"..., 4096) = 55
close(4) = 0
brk(0x2713000) = 0x2713000
brk(0x270a000) = 0x270a000
open("/etc/mysql/mysql.conf.d/", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
getdents(4, /* 4 entries */, 32768) = 128
close(4) = 0
stat("/etc/mysql/mysql.conf.d/mysqld.cnf", {st_mode=S_IFREG|0644, st_size=3028, ...}) = 0
open("/etc/mysql/mysql.conf.d/mysqld.cnf", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=3028, ...}) = 0
read(4, "#\n# The MySQL database server co"..., 4096) = 3028
close(4) = 0
stat("/etc/mysql/mysql.conf.d/mysqld_safe_syslog.cnf", {st_mode=S_IFREG|0644, st_size=21, ...}) = 0
open("/etc/mysql/mysql.conf.d/mysqld_safe_syslog.cnf", O_RDONLY) = 4
fstat(4, {st_mode=S_IFREG|0644, st_size=21, ...}) = 0
read(4, "[mysqld_safe]\nsyslog\n", 4096) = 21
close(4) = 0
read(3, "", 4096) = 0
close(3) = 0
stat("/home/kuhrusty/.my.cnf", 0x7ffe13e99af0) = -1 ENOENT (No such file or directory)
stat("/home/kuhrusty/.mylogin.cnf", 0x7ffe13e99af0) = -1 ENOENT (No such file or directory)
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=64*1024}) = 0
setrlimit(RLIMIT_NOFILE, {rlim_cur=5000, rlim_max=5000}) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=5000, rlim_max=5000}) = 0
umask(026) = 02
open("/etc/localtime", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=2845, ...}) = 0
read(3, "TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\5\0\0\0\5\0\0\0\0"..., 4096) = 2845
lseek(3, -1811, SEEK_CUR) = 1034
read(3, "TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\5\0\0\0\5\0\0\0\0"..., 4096) = 1811
close(3) = 0
uname({sysname="Linux", nodename="tentacle", ...}) = 0
brk(0x2732000) = 0x2732000
brk(0x2724000) = 0x2724000
lstat("/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/usr/local", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/usr/local/mysqld-test", {st_mode=S_IFDIR|0777, st_size=4096, ...}) = 0
lstat("/usr/local/mysqld-test/data", 0x7ffe13e9d1d0) = -1 ENOENT (No such file or directory)
open("/usr/share/mysql/english/errmsg.sys", O_RDONLY) = 3
read(3, "\376\376\3\1\1\0\335\26\1\0008\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\10\0", 32) = 32
read(3, "\0\0\0\0\10\0\0\0\20\0\0\0\23\0\0\0\27\0\0\0D\0\0\0m\0\0\0\231\0\0\0"..., 4320) = 4320
read(3, "hashchk\0isamchk\0NO\0YES\0Can't cre"..., 71389) = 71389
close(3) = 0
stat("/usr/local/mysqld-test/share/mysql/charsets/Index.xml", 0x7ffe13e9e2e0) = -1 ENOENT (No such file or directory)
futex(0x1ddcf48, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x2745000) = 0x2745000
open("/usr/local/mysqld-test/data/", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mkdir("/usr/local/mysqld-test/data/", 0750) = -1 EACCES (Permission denied)
OK, now, I think that's where things go wrong (note: make sure you scroll to the bottom)... but why? Anyone can create a file there!
write(2, "mysqld: ", 8) = 8
write(2, "Can't create directory '/usr/loc"..., 87) = 87
write(2, "\n", 1) = 1
WTF?? With this problem, the 14.04 -> 16.04 upgrade now ranks as about the third biggest mistake of my life... I feel like I've suffered one of those traumatic brain injuries where you forget how to read. Those permissions are right, right?? Running mysqld --initialize under sudo doesn't make a difference. Is there some incredibly stupid thing I'm doing wrong?
