What happens is that when executing the command "sudo apt-get install mysql-server" it throws me the following error:
● mysql.service - MySQL Community Server
     Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: exit-code) since Tue 2021-12-28 16:30:45 CST; 6ms ago
    Process: 10525 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=1/FAILURE)
Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: mysql.service: Scheduled restart job, restart counter is at 1. Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: Stopped MySQL Community Server. Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: Starting MySQL Community Server... Dec 28 16:30:45 exatoon27-Inspiron-3558 mysql-systemd-start[10534]: MySQL system database not found in /var/lib/mysql. Please run mysqld --initialize. Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: mysql.service: Control process exited, code=exited, status=1/FAILURE Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: mysql.service: Failed with result 'exit-code'. Dec 28 16:30:45 exatoon27-Inspiron-3558 systemd[1]: Failed to start MySQL Community Server. dpkg: error processing package mysql-server-8.0 (--configure): installed mysql-server-8.0 package post-installation script subprocess returned error exit status 1 dpkg: dependency problems prevent configuration of mysql-server: mysql-server depends on mysql-server-8.0; however: Package mysql-server-8.0 is not configured yet.
dpkg: error processing package mysql-server (--configure): dependency problems - leaving unconfigured No apport report written because the error message indicates its a followup error from a previous failure. Errors were encountered while processing: mysql-server-8.0 mysql-server E: Sub-process /usr/bin/dpkg returned an error code (1)
It should be noted that I already tried the following in the order in which they are:
sudo apt-get purge mysql*
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get dist-upgrade
