16
I have been following the instructions on this page to install mysql on on Ubuntu 16.04.
I am half way down that page at the section titled "MySQL Install and Configure" and I run the command sudo apt-get install mysql-server. I have hit an error however, here is the output of that error in my terminal:
Preconfiguring packages ...
Selecting previously unselected package mysql-common.
(Reading database ... 41515 files and directories currently installed.)
Preparing to unpack .../mysql-common_5.7.12-0ubuntu1_all.deb ...
Unpacking mysql-common (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-client-5.7.
Preparing to unpack .../mysql-client-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-client-5.7 (5.7.12-0ubuntu1) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up mysql-common (5.7.12-0ubuntu1) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Selecting previously unselected package mysql-server-5.7.
(Reading database ... 41563 files and directories currently installed.)
Preparing to unpack .../mysql-server-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-server-5.7 (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-server.
Preparing to unpack .../mysql-server_5.7.12-0ubuntu1_all.deb ...
Unpacking mysql-server (5.7.12-0ubuntu1) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for systemd (229-4ubuntu4) ...
Setting up mysql-client-5.7 (5.7.12-0ubuntu1) ...
Setting up mysql-server-5.7 (5.7.12-0ubuntu1) ...
update-alternatives: using /etc/mysql/mysql.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
mysql_upgrade: Got error: 1045: Access denied for user 'debian-sys-maint'@'localhost' (using password: YES) while connecting to the MySQL server
Upgrade process encountered error and will not continue.
mysql_upgrade failed with exit status 11
dpkg: error processing package mysql-server-5.7 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.7; however:
  Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
 mysql-server-5.7
 mysql-server
This is my first time setting up a server and also installing mysql. Not sure if this may be a possible cause of the error, but I had previously tried to install mysql but not following the LAMP process (I am newb figuring this out) and that was unsuccessful and I had to uninstall.
6 Answers6
17
This answer is also in answer to 16.04 upgrade broke mysql-server but which I cannot answer as the admin locked it to 10 reputation.
The error in APT occurs during the upgrade of Ubuntu to 16.04 (xenial) and Mysql from 5.5 to 5.7. Due to some packaging issues the APT upgrade ends in limbo because the post installation script of Mysql-server-5.7 fails to complete.
To solve the problem, try these steps:
  1. apt purge mysql-server and apt autoremove to clean all traces of the old MYSQL. The database data will not be destroyed.
  2. Remove everything from /etc/mysql directory.
  3. Verify there is no old Mysql packages left installed: dpkg -l | grep mysql
  4. apt install mysql-server to install
If these steps end in the same incomplete install, try the next step:
  1. Tail -n 20 /var/log/mysql/error.log
  2. The errors could be a. bad password for debian-sys-maint b. no memory for Innodb
Solve 2a: You need to upgrade the Mysql system tables from 5.5 to 5.7
Edit my.cnf to include under '[mysqld]' the line "skip-grant-tables", service mysql start, and mysql_upgrade --force -u root -p
Solve 2b: You are short of memory for Mysql Innodb pool (are you on a micro-size server?)
Edit my.cnf to include under '[mysqld]' the line innodb_buffer_pool_size = 20M
the default innodb pool is 128M, that is tight in a 512M VM
To clear the APT error, do the post install again
dpkg --configure -a
Kaceo
  • 171
Another good solution:
sudo apt-get purge mysql* && sudo apt-get install mysql-server
Eric Carvalho
  • 55,453
Completely removing mysql and reinstalling was the solution I eventually came to. Although I had tried to uninstall and reinstall once unsuccessfully (thus bringing me to ask this question). I tried a more thorough uninstall after finding the advice on this page: Uninstall MySQL completely
Following the uninstall directions there and reinstalling solved the problem.
This worked for me :
sudo apt-get remove --purge mysql*
This command will ask You if You want to REMOVE your databases from /var/lib/mysql and also will remove all other instances of mysql !
So make a BACKUP of Your databases first !
After this I could install database by issuing the command :
Try to remove all packages and files, then re-install the "mysql-server"
sudo apt-get remove --purge mysql-\*
sudo rm -rf /var/lib/mysql
Spl2nky
  • 113
First you have remove all packages of mysql-server:
Then install:
sudo apt-get install lamp-server^
Or you can do:
Zanna
  • 72,312
