ubuntu 16.04.3 - when trying to do:
sudo apt-get update
This is what I get:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have been kept back:
  libegl1-mesa libgl1-mesa-dri libinput10 libmirclient9 libwayland-egl1-mesa libxatracker2
  linux-headers-generic linux-headers-virtual linux-image-virtual linux-virtual
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up mysql-server-5.7 (5.7.19-0ubuntu0.16.04.1) ...
ERROR: Unable to start MySQL server:
2017-09-04T11:14:27.542500Z 0 [ERROR] unknown variable 'validate_password_check_user_name=1'
2017-09-04T11:14:27.546320Z 0 [ERROR] Aborting
Please take a look at https://wiki.debian.org/Teams/MySQL/FAQ for tips on fixing common upgrade issues.
Once the problem is resolved, run apt-get --fix-broken install to retry.
dpkg: error processing package mysql-server-5.7 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.7; however:
  Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 mysql-server-5.7
 mysql-server
Yaron
  • 13,453
I had the same problem, most probably resulting from installing/testing/removing lots of software. I resolved it by purging and re-installing mysql-server.
apt-get purge mysql-common
Of course, take care of your mysql data before you purge it. I'm not sure wether your data would survive the above commandline. I didn't care about my data, because it was just rubbish I used for testing.
Hope this helps.
TomTomTom
TomTomTom
  • 483
I needed to install mysql this way:
https://www.digitalocean.com/community/tutorials/how-to-install-the-latest-mysql-on-ubuntu-16-04
Works ok now.
