After problems with MySQL server that couldn't finish an update properly (5.7.24). I followed this answer. So basically, I can come back in a "stable" state when after running the following commands:
sudo apt update
sudo apt-get update
sudo apt-get upgrade
sudo apt-get autoremove
sudo apt-get autoclean
sudo dpkg --configure -a
All is working, MySQL is removed and no error are returned. (I could do the apt purge without error). There are no more /etc/mysql nor /var/lib/mysql directories. And the last dpkg doesn't find anything to do and returns nothing.
I reboot to be sure. But now, when I am doing :
sudo apt-get install mysql-server
I am getting this error:
dpkg: error processing package mysql-server-5.7 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.7; however:
  Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
 mysql-server-5.7
 mysql-server
Saying that is still not configured and there are dependency problems. So the install can't finish with success.
When running:
sudo dpkg-reconfigure mysql-server-5.7
It returns:
/usr/sbin/dpkg-reconfigure: mysql-server-5.7 est cassé ou partiellement installé
Can't be done because mysql-server-5.7 is broken or partially installed. So, is there a way to really return to a fresh state? I don't have to keep existing MySQL databases or configurations. Thanks.
COil
  • 900
Ok I will answer to my question, thanks for the help, so what I have done after many try/error:
First, ensure you can run these commands without any error: (don't hesitate to reboot to avoid locks in apt)
sudo apt-get remove --purge mysql*
sudo apt update
sudo apt-get update
Delete: (do backup before if you want but do no leave the files in these directories, even with .bak or .old extensions)
  • /etc/mysql
  • /var/lib/mysql
If you have an error mentioning alternatives, run: (replace my.cnf) by the file indicated in the error message)
sudo update-alternatives --remove my.cnf
Then reinstall:
sudo apt install mysql-server
Check now, if at least the mysql service is running:
sudo service mysql status
If still not OK, try to force reinstall:
sudo apt install mysql-server --reinstall
And reconfigure:
kshishkin
  • 128
COil
  • 900
Remove All
sudo apt-get remove --purge mysql-server mysql-client mysql-common -y
sudo apt-get autoremove -y
rm -rf /etc/mysql
Greetings!
