apt-get got stuck while installing mysql-server. I don't know why but it just stopped working and never continued. I had to reboot the machine in the middle of the setup process.
Now, if I try to install or purge the mysql-server package, apt-get tries to configure mysql-server first (tells me its not installed before that) and cancels with a error message:
Sub-process /usr/bin/dpkg returned an error code(1)
apt-get also tells me that two packages have not been successfully installed or removed.
this is the complete console output:
christian@devbox:~$ sudo apt-get install mysql-server
[sudo] password for christian:
Reading package lists... Done
Building dependency tree
mysql-server is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up mysql-server-5.5 (5.5.32-0ubuntu7) ...
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing mysql-server-5.5 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 mysql-server-5.5
 mysql-server
christian@devbox:~$
I don't know why the actual package would be faulty so I would recommend forcing the install through dpkg.
sudo dpkg -i --force-all package.deb
you can find the actual package in /var/cache/apt/archives/
labarna
  • 2,632
