After upgrading to Ubuntu 16.04, I noticed mysql was having mind-boggling errors. Convinced, it was a broken setup, I tried running a purge of mysql. That didn't seem to delete everything, so I tried doing it myself:
sudo rm -r /etc/mysql
sudo rm -r /usr/share/mysql-workbench
sudo rm -r /usr/share/mysql-common
This was a mistake. Don't EVER try to do this. Now mysql won't even install correctly. I've tried reinstalling the dependancies:
sudo apt-get install --reinstall $(apt-cache depends mysql-server | grep -Po 'Depends:\s+\K[^ ]+$' | tr '\n' ' ' )
And the packages themselves:
sudo apt install mysql-workbench mysql-server --reinstall
But I get all sorts of cryptic errors, such as:
sudo apt-get install --reinstall mysql-server
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
E: Internal Error, No file name for mysql-server:amd64
And uninstalling
sudo apt-get remove mysql-common
libmysqlclient20 : Depends: mysql-common (>= 5.5) but it is not going to be installed
mariadb-client-core-10.0 : Depends: mariadb-common (>= 10.0.24-7) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Or if I reconfigure
sudo dpkg --configure -a
Setting up mysql-server-5.7 (5.7.12-0ubuntu1) ...
/var/lib/dpkg/info/mysql-server-5.7.postinst: line 112: /usr/share/mysql-common/configure-symlinks: No such file or directory
dpkg: error processing package mysql-server-5.7 (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.7; however:
Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
mysql-server-5.7
mysql-server
Or if I Force install:
sudo apt-get -f install
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
No apport report written because the error message indicates its a followup error from a previous failure.
mysql-server-5.7
mysql-server
Or if I do a purge:
sudo apt-get -f purge mysql-server
The following packages will be REMOVED:
mysql-server*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 159 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 348226 files and directories currently installed.)
Removing mysql-server (5.7.12-0ubuntu1) ...
mysql-server-5.7
Is apt unable to recover from a partial install? Do I have to reinstall the OS??
