When I install mysql-server, I get the following error:
Reading package lists... Done
Building dependency tree
 mysql-server : Depends: mysql-server-5.7 but it is not going to be installed
However, I am able to install the mysql-client without any problem. I have tried all the solutions given for related questions but nothing worked. The related problems I have tried are:
The following question also does not match with my problem: Error in installing Mysql-server in ubuntu16.04
Could anyone help me to resolve this issue. Thanks in advance.
Gobinath
  • 3,392
Finally, I found a solution from this site.
As stated in other answers, uninstall all the existing mysql modules. To get the list of installed mysql modules, use the following command:
dpkg -l | grep mysql
Download the mysql-apt-config_0.7.3-1_all.deb from the MySQL website.
Install the package using the following command:
sudo dpkg -i mysql-apt-config_0.7.3-1_all.deb
Create a new file /etc/apt/preferences.d/mysql with this content
Package: *
Pin: origin "repo.mysql.com"
Pin-Priority: 999
Run the following command to update the cache
sudo apt update
Run the following command to install MySQL
sudo apt install mysql-client mysql-server libmysqlclient-dev
Gobinath
  • 3,392
