20
I have followed all the instructions on the winehq page. In particular, I have run the following commands:
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/winehq.key
sudo apt-key add winehq.key
sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
The first three of the above seemed to work fine. However, the last command gives me the following error:
The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 5.0.0~bionic) E: Unable to correct problems, you have held broken packages.
I'm running Lubuntu 18.04.3 on a USB live stick. (However, if I remember correctly, a couple days ago I got the exact same error on a normal hard disk Lubuntu 18.04.3 installation.)
I've read that a lot of people get similar errors. Unfortunately I haven't found any solutions online that worked.
Any help would be much appreciated. Thanks!
EDIT: Thanks for the comments and suggestions everyone. I'll try them out later today.
In the mean time, here's something I don't understand. Ubuntu 18.04 has been around for almost two years now. In all that time, surely somebody has successfully installed wine, right? What did they do to get it working?
N0rbert
  • 103,263
Ben W
  • 333
Analysis
The WineHQ repository misses the dependencies for wine-stable package.
I have reported a bug 48513 to WineHQ bugzilla.
The main problem here is bad documentation, which is written in non-reproducible way.
The Rosanne DiMesio's main idea is "People who don't bother to read the directions are always going to have problems.".
So we need to write our own documentation until WineHQ-officials become smarter.
The problem with dependencies was caused by the FAudio dependency, which is not contained in Debian/Ubuntu and WineHQ repositories. We can determine the exact package name by using command below and analyzing of their output:
$ sudo apt-get install wine-stable-amd64
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: wine-stable-amd64 : Depends: libfaudio0 but it is not installable Recommends: libcapi20-3 but it is not going to be installed Recommends: libodbc1 but it is not going to be installed Recommends: libosmesa6 but it is not going to be installed Recommends: libsdl2-2.0-0 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
The aforementioned libfaudio0 package is available only for Ubuntu 19.10 and upcoming 20.04 LTS.
Solution
We need to follow official WineHQ guide for Ubuntu partially:
sudo apt update
Note: if you have WineHQ repository added - remove it with
sudo apt-add-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
to prevent the mess of repositories and then proceed.
Then we need to add other repository from OpenSuse Build Service to get libfaudio0 installed:
wget -q https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/Release.key -O Release.key -O- | sudo apt-key add -
sudo apt-add-repository 'deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./'
sudo apt-get update
and only after this install one of WineHQ packages:
# Stable branch
sudo apt install --install-recommends winehq-stable
#Development branch
#sudo apt install --install-recommends winehq-devel
#Staging branch
#sudo apt install --install-recommends winehq-staging
N0rbert
  • 103,263
Just an FYI, the Wine team have no intention of updating their misleading documentation, so this will continue to be problem on any distro based on 18.04 LTS:
The problem is with your system, not the packages.
You are probably missing FAudio, which is now a dependency for wine-stable, as stated clearly at the top of https://wiki.winehq.org/Ubuntu. The wiki also directs users to https://forum.winehq.org/viewtopic.php?f=8&t=32192 for instructions on how to install FAudio for bionic. Apparently you overlooked that part.
If that doesn't fix it, follow the instructions in https://wiki.winehq.org/FAQ#How_do_I_solve_dependency_errors_when_trying_to_install_Wine.3F to figure out exactly what dependencies you are missing. If you need further help, ask for it on the forum. Bugzilla is not for user support.
Friendly.
PopeJamal
  • 301
As another temporary solution, you may install previous version with command
apt-get install -y --install-recommends winehq-stable=4.0.3~bionic \
wine-stable=4.0.3~bionic wine-stable-amd64=4.0.3~bionic wine-stable-i386=4.0.3~bionic
It can be upgraded after maintainers fix their repository.
If the installation of winehq-stable gives the same error even after following all the steps in @N0rbert's answer.
Execute this command given in this link
sudo apt-get install libgnutls30:i386 libldap-2.4-2:i386 libgpg-error0:i386 libxml2:i386 libasound2-plugins:i386 libsdl2-2.0-0:i386 libfreetype6:i386 libdbus-1-3:i386 libsqlite3-0:i386
I had the same problem and this worked for me.
