So I'm operating on Ubuntu 18.04 and whenever I try to install the Wine this is what I get.
$ sudo apt-get install --install-recommends wine-stable
Reading package lists... Done
Building dependency tree
 wine-stable : Depends: wine-stable-i386 (= 5.0.0~bionic)
               Depends: wine-stable-amd64 (= 5.0.0~bionic) but it is not going to be installed
Then when I try to add $ sudo apt-get install wine-stable-amd64 I get this.
[sudo] password for user:
 wine-stable-amd64 : Depends: libfaudio0 but it is not installable
                     Recommends: libsdl2-2.0-0 but it is not installable
I'm new to Ubuntu and I am not the best with it, so I'd really appreciate some assistance with what this issue means and how to correct it.
Here is the Ubuntu 18.04 method of installing Wine 5. It appears on this website.
I will detail the steps:
Enable 32 bit support:
sudo dpkg --add-architecture i386
Add repositories for Wine: Download the GPG key of the official Wine package repository:
wget -nc https://dl.winehq.org/wine-builds/winehq.key
Add the Wine GPG key:
sudo apt-key add winehq.key
Add the official Wine package repository:
sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
Download the OpenSUSE Wine repository’s GPG key:
wget -nc https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/Release.key
Add the GPG key:
sudo apt-key add Release.key
Add the OpenSUSE Wine repository:
echo "deb http://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04 ./" | sudo tee /etc/apt/sources.list.d/wine-obs.list
Update the APT package repository cache:
sudo apt update
You’re ready to install Wine 5:
sudo apt install --install-recommends winehq-stable
Press Y and then press Enter
Once Wine 5 is installed, you can configure it.
winecfg
