I am trying to install wine on Ubuntu 18.4 but am completely failing. I have activated sudo dpkg --add-architecture i386 and then try to install wine, with the below output. There are too many dependencies for me to install I believe.
hutber@hutber:~$ sudo apt-get install wine1.6
Reading package lists... Done
Building dependency tree state information... Done
The following packages have unmet dependencies.
wine1.6 : Depends: wine1.6-amd64 (= 1:1.6.2-0ubuntu14.2)
Depends: wine1.6-i386 (= 1:1.6.2-0ubuntu14.2)
hutber@hutber:~$ sudo apt-get install wine1.6-i386
wine1.6-i386:i386 : Depends: libasound2:i386 (>= 1.0.16)
Depends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Depends: libgphoto2-6:i386 (>= 2.5.9) but it is not going to be installed
Depends: libgphoto2-port12:i386 (>= 2.5.9) but it is not going to be installed
Depends: liblcms2-2:i386 (>= 2.2+git20110628) but it is not going to be installed
Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
Depends: libmpg123-0:i386 (>= 1.13.7) but it is not going to be installed
Depends: libopenal1:i386 (>= 1.14) but it is not going to be installed
Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
Depends: libncurses5:i386 but it is not going to be installed
If I try to install via the software manager it says "Not available"
I do not have broken packages:
hutber@hutber:~$ sudo apt-get -f install && sudo apt autoremove
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
[Edit] - Information from comments
hutber@hutber:~$ sudo apt-get install -y --install-recommends winehq-stable=4.0.3~bionic \
> wine-stable=4.0.3~bionic wine-stable-amd64=4.0.3~bionic wine-stable-i386=4.0.3~bionic
wine-stable-i386:i386 : Depends: libasound2:i386 (>= 1.0.16)
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgphoto2-port12:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
Depends: libpcap0.8:i386 (>= 0.9.8) but it is not going to be installed
Depends: libpulse0:i386 (>= 0.99.1) but it is not going to be installed
Depends: libudev1:i386 (>= 183) but it is not going to be installed
Depends: libasound2-plugins:i386 but it is not going to be installed
Depends: libncurses6:i386 but it is not installable or
libncurses5:i386 but it is not going to be installed or
libncurses:i386 but it is not installable
Recommends: libcapi20-3:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libdbus-1-3:i386 but it is not going to be installed
Recommends: libfontconfig1:i386 but it is not going to be installed
Recommends: libfreetype6:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgnutls30:i386 but it is not going to be installed or
libgnutls28:i386 but it is not installable or
libgnutls26:i386 but it is not installable
Recommends: libgsm1:i386 but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
Recommends: libjpeg62-turbo:i386 but it is not installable or
libjpeg8:i386 but it is not going to be installed
Recommends: libkrb5-3:i386 but it is not going to be installed
Recommends: libodbc1:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libpng16-16:i386 but it is not going to be installed or
libpng12-0:i386 but it is not going to be installed
Recommends: libsane:i386 but it is not going to be installed or
libsane1:i386 but it is not installable
Recommends: libsdl2-2.0-0:i386 but it is not going to be installed
Recommends: libtiff5:i386 but it is not going to be installed
Recommends: libv4l-0:i386 but it is not going to be installed
Recommends: libxcomposite1:i386 but it is not going to be installed
Recommends: libxcursor1:i386 but it is not going to be installed
Recommends: libxi6:i386 but it is not going to be installed
Recommends: libxinerama1:i386 but it is not going to be installed
Recommends: libxrandr2:i386 but it is not going to be installed
Recommends: libxrender1:i386 but it is not going to be installed
Recommends: libxslt1.1:i386 but it is not going to be installed
