sudo apt install --install-recommends winehq-stable
[sudo] password for krishanu:
Reading package lists... Done
Building dependency tree
winehq-stable : Depends: wine-stable (= 5.0.3~groovy)
This wine installation procedure was tested for gaming purposes and is running on Xubuntu 20.04 LTS machines.
a) Go to: https://wiki.winehq.org/Ubuntu for aditional information
b) Open the app Terminal and execute the following commands:
su – administratoraccount and password
c) Activate 32 bits architecture:
sudo dpkg --add-architecture i386
d) Download repository key:
wget -nc https://dl.winehq.org/wine-builds/winehq.key and then sudo apt-key add winehq.key
e) Add the repository for ubuntu 20.04:
sudo add-apt-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ focal main'
f) Update packages:
sudo apt update
g) Install the wine package suitable for the needs. Please, see Wine FAQ under the section 2.2 Which version of Wine should I use? on https://wiki.winehq.org/FAQ#Which_version_of_Wine_should_I_use.3F In this case the Development branch is used.
sudo apt install --install-recommends winehq-devel
h) Install winetricks:
sudo apt install winetricks
i) Install dxvk package:
sudo apt install dxvk
Note:
Checking wine version installed: wine --version
- 70
