I'm running Ubuntu 18.04.4, and am trying to download Divinity 2. I have it installed, but whenever I try to run it, I get the following error:
"bash: ./SupportTool.exe: cannot execute binary file: Exec format error"
I got the following results when checking for compatibility:
arch: x86_64
file: EoCApp.exe: PE32+ executable (GUI) x86-64, for MS Windows
Is there a way to make this compatible? Please let me know what other details I can provide.
Thank you,
Andrew
Andrew
  • 13
You can't launch native Windows application through vanilla Ubuntu, you have to use WINE in order to execute them.
Wine (originally an acronym for "Wine Is Not an Emulator") is a compatibility layer capable of running Windows applications on several POSIX-compliant operating systems, such as Linux, macOS, & BSD.
To install please refer to official documentation https://wiki.winehq.org/Ubuntu, alternatively execute following command on terminal.
sudo dpkg --add-architecture i386
wget -nc -qO- https://dl.winehq.org/wine-builds/winehq.key | sudo apt-key add -
sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
sudo apt install --install-recommends winehq-staging
You can then launch the application through Wine
wine SupportTool.exe
You can check Wine's compatibility for Divinity 2 → https://appdb.winehq.org/objectManager.php?sClass=application&iId=18266
Liso
  • 15,677
