I'm sure this has showed up here before, but I've searched for and tried many things, never being able to solve it.
I was trying to install wine to run windows applications, but when I tried in the command line I always got the message "Unable to correct problems, you have held broken packages.". I ran commands such as sudo apt upgrade and full-upgrade as well as update, sudo apt-get install -f, I tried using sudo dpkg, I tried purging the file that I think is defective (wine-stable), I went to Synaptic package manager, where I found the 4 files that were broken, but when trying to repair them Synaptic failed saying there were broken packages that needed to be fixed before that, so I was stuck in a loop.
The last thing that happened before writing this is the command line returning "0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded." whenever I tried to upgrade, purge, remove or autoremove the defective files, saying that the files weren't installed, didn't exist and such. But if I tried to install wine again using sudo apt-get install winehq-stable it still showed me the same message, that there are broken packages.
I ran out of ideas, any help would be appreciated.
edit: okay I'll paste some outputs here, sorry for not formatting correctly, it's my first time here.
guilherme@guilherme-dell:~$ sudo apt-get install winehq-stable
[sudo] password for guilherme:
Reading package lists... Done
Building dependency tree
 winehq-stable : Depends: wine-stable (= 5.0.0~bionic)
guilherme@guilherme-dell:~$ sudo apt upgrade
Calculating upgrade... Done
guilherme@guilherme-dell:~$ sudo apt autoremove
guilherme@guilherme-dell:~$ sudo apt-get install -f
guilherme@guilherme-dell:~$ sudo apt-get install wine-stable
 wine-stable : Depends: wine-stable-i386 (= 5.0.0~bionic)
               Depends: wine-stable-amd64 (= 5.0.0~bionic) but it is not going to be installed
