It is my terminal command
sudo apt install --install-recommends winehq-staging
and it is my answer
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: winehq-staging : Depends: wine-staging (= 5.21~bionic) E: Unable to correct problems, you have held broken packages.
I'm getting confuse how to install wine on Ubuntu 18.04 because I need that
user.dz
  • 49,176
Why use the "staging" version? Just run:
sudo apt install wine
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
