I am attempting to install the latest development version of Wine (wine-devel) under Ubuntu 18.04 Bionic Beaver from the WineHQ PPA but the following error message stops me:
andrew@corinth:~$ sudo apt install --install-recommends winehq-devel
Reading package lists... Done
Building dependency tree
 winehq-devel : Depends: wine-devel (= 5.0.0~bionic)
andrew@corinth:~$
How do I successfully complete the installation of Wine Development version under Ubuntu 18.04? I would prefer to use only the Wine PPA and not add another PPAs such as the OpenSuse Build Service as suggested in other Ask Ubuntu answers...
andrew.46
  • 39,359
This error comes about because WineHQ wine-devel now requires the installation of an FAudio package for installation to succeed. Fortunately this can be worked around fairly easily under Ubuntu 18.04 by using the following 3 relatively simple steps:
1. Add the Wine PPA
You will need to add the 32bit architecture to your 64bit system as well as add the Wine PPA and key:
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/winehq.key
sudo apt-key add winehq.key
sudo apt-get update
2. Add FAudio
For Ubuntu 18.04 (a different approach is required for newer versions of Ubuntu) the following steps should be used next:
cd ~/Downloads
wget https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/amd64/libfaudio0_19.07-0~bionic_amd64.deb
wget https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/i386/libfaudio0_19.07-0~bionic_i386.deb
sudo dpkg -i libfaudio0_19.07-0~bionic_amd64.deb libfaudio0_19.07-0~bionic_i386.deb
sudo apt --fix-broken install
This is perhaps a little easier than adding yet another PPA, the OpenSuse Build Service PPA...
3. Install Wine -devel
And now finally install the latest development version of Wine:
Finally test your installation, as seen on my own system:
andrew@corinth:~$ wine --version
wine-5.0
andrew@corinth:~$
And now you are right to go :)
References:
andrew.46
  • 39,359
