I've followed this guide to installing wine: https://wiki.winehq.org/Ubuntu
When running: sudo apt install --install-recommends winehq-stable
I get:
 winehq-stable : Depends: wine-stable (= 5.0.0~eoan)
I've tried running the commands for bionic instead of eoan with no success. I tried following this guide with no success: http://ubuntuhandbook.org/index.php/2020/01/install-wine-5-0-stable-ubuntu-18-04-19-10/
Any help would be appreciated, I'm new to Linux. Just came over from Windows.
This question did not help: can't install wine on ubuntu (actually lubuntu) 18.04
This is how it went:
skylar@Eden:~$ sudo apt-add-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
[sudo] password for skylar:
skylar@Eden:~$ sudo apt update
Hit:1 https://dl.winehq.org/wine-builds/ubuntu eoan InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu bionic InRelease
Get:3 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [307 kB]
Get:7 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [38.5 kB]
Get:8 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [73.8 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [140 kB]
Get:10 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [265 kB]
Get:11 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [196 kB]
Get:12 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [17.6 kB]
Get:13 http://us.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [449 kB]
Get:14 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [41.5 kB]
Get:15 http://us.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,468 B]
Get:16 http://us.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7,980 B]
Get:17 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [42.1 kB]
Get:18 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
Get:19 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [111 kB]
Get:20 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
Fetched 1,964 kB in 2s (1,246 kB/s)
Reading package lists... Done
Building dependency tree
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
skylar@Eden:~$ apt list --upgradable
Listing... Done
xserver-common/bionic-updates,bionic-updates 2:1.19.6-1ubuntu4.4 all [upgradable from: 2:1.19.6-1ubuntu4.3]
xserver-xephyr/bionic-updates 2:1.19.6-1ubuntu4.4 amd64 [upgradable from: 2:1.19.6-1ubuntu4.3]
xwayland/bionic-updates 2:1.19.6-1ubuntu4.4 amd64 [upgradable from: 2:1.19.6-1ubuntu4.3]
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
skylar@Eden:~$ upgrade
upgrade: command not found
skylar@Eden:~$ sudo apt-get update
skylar@Eden:~$ sudo apt-get upgrade
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  libfwup1
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  xserver-common xserver-xephyr xwayland
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1,813 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 165284 files and directories currently installed.)
Preparing to unpack .../xserver-common_2%3a1.19.6-1ubuntu4.4_all.deb ...
Unpacking xserver-common (2:1.19.6-1ubuntu4.4) over (2:1.19.6-1ubuntu4.3) ...
Preparing to unpack .../xserver-xephyr_2%3a1.19.6-1ubuntu4.4_amd64.deb ...
Unpacking xserver-xephyr (2:1.19.6-1ubuntu4.4) over (2:1.19.6-1ubuntu4.3) ...
Preparing to unpack .../xwayland_2%3a1.19.6-1ubuntu4.4_amd64.deb ...
Unpacking xwayland (2:1.19.6-1ubuntu4.4) over (2:1.19.6-1ubuntu4.3) ...
Setting up xserver-common (2:1.19.6-1ubuntu4.4) ...
Setting up xserver-xephyr (2:1.19.6-1ubuntu4.4) ...
Setting up xwayland (2:1.19.6-1ubuntu4.4) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
skylar@Eden:~$ sudo apt-get dist-upgrade
  libfwup1
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
skylar@Eden:~$ wget -nv https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/Release.key -O Release.key
2020-03-22 11:57:10 URL:https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/Release.key [1089/1089] -> "Release.key" [1]
skylar@Eden:~$ sudo apt-key add - < Release.key
OK
skylar@Eden:~$ sudo apt-add-repository 'deb https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04/ ./'
Get:6 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04 ./ InRelease [1,562 B]
Get:7 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04 ./ Packages [21.8 kB]
Fetched 23.4 kB in 1s (17.9 kB/s)
Hit:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
Hit:6 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_18.04 ./ InRelease
skylar@Eden:~$ # Stable branch
skylar@Eden:~$ sudo apt install --install-recommends winehq-stable
skylar@Eden:~$
skylar@Eden:~$ #Development branch
skylar@Eden:~$ #sudo apt install --install-recommends winehq-devel
skylar@Eden:~$
skylar@Eden:~$ #Staging branch
skylar@Eden:~$ #sudo apt install --install-recommends winehq-staging
N0rbert
  • 103,263
