I am trying to install wine for the Ubuntu 20.04 LTS (Focal Fossa) that I am using via the guidelines provided by the wine website.
These are the steps I have made:
sudo dpkg --add-architecture i386
wget -nc https://dl.winehq.org/wine-builds/winehq.key
sudo apt-key add winehq.key
sudo add-apt-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ groovy main'
And now the last command in the process seems to have an issue that I have not been able to figure out. The command:
sudo apt install --install-recommends winehq-stable
After I insert this command I get this:
"Some packages could not be installed. This may mean that you have
The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 6.0.0~groovy-1) E: Unable to correct problems, you have held broken packages."
How do I solve this?
Pablo Bianchi
  • 17,371
Syphoonfi
  • 23
