I have been trying to install winehq-staging (to use with lutris) on Ubuntu 18.04.
I followed the standard steps, but always end up with:
sudo apt install --install-recommends winehq-staging
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: winehq-staging : Depends: wine-staging (= 5.10~focal) E: Unable to correct problems, you have held broken packages.
I have no idea how to fix this error, because it does not tell me which dependencies are actually missing!
What can I do to succesfully install winehq-staging?
Edit:
I tried both the options commented by @N0rbert and @bhordupur, but both did not work to solve my issues. I get the exact same error message. I did, however, also run sudo apt-get install wine-stable-amd64 to figure out which packages are missing, which gave the following output:
The following packages have unmet dependencies: wine-stable-amd64 : Depends: libc6 (>= 2.29) but 2.27-3ubuntu1 is to be installed Depends: libgcc-s1 (>= 3.0) but it is not installable Depends: libvkd3d1 (>= 1.0) but it is not installable E: Unable to correct problems, you have held broken packages.
Does anyone know what this output means precisely? It reads like I might be unable to install these dependencies in order to get winehq-stable to work?
