Hello I try to install wine-stable in my ubuntu 18.04, but I am not able to install it, all of them depend on the packages I have installed already.
$ sudo apt install wine-stable
Reading package lists... Done
Building dependency tree
wine-stable-amd64 : Depends: libfaudio0 but it is not installable
Recommends: libcapi20-3 but it is not going to be installed
Recommends: libodbc1 but it is not going to be installed
Recommends: libosmesa6 but it is not going to be installed
wine-stable-i386:i386 : Depends: libasound2:i386 (>= 1.0.16)
Depends: libfaudio0:i386 but it is not installable
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgphoto2-port12:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
Depends: liblcms2-2:i386 (>= 2.2+git20110628) but it is not going to be installed
Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
Depends: libmpg123-0:i386 (>= 1.13.7) but it is not going to be installed
Depends: libopenal1:i386 (>= 1.14) but it is not going to be installed
Depends: libpcap0.8:i386 (>= 0.9.8) but it is not going to be installed
Depends: libpulse0:i386 (>= 0.99.1) but it is not going to be installed
Depends: libudev1:i386 (>= 183) but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Depends: libxext6:i386 but it is not going to be installed
Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
Depends: ocl-icd-libopencl1:i386 but it is not going to be installed or
libopencl1:i386
Depends: ocl-icd-libopencl1:i386 (>= 1.0) but it is not going to be installed or
libopencl-1.1-1:i386
Depends: zlib1g:i386 (>= 1:1.1.4) but it is not going to be installed
Depends: libasound2-plugins:i386 but it is not going to be installed
Depends: libncurses6:i386 but it is not installable or
libncurses5:i386 but it is not going to be installed or
libncurses:i386 but it is not installable
Recommends: libcapi20-3:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libdbus-1-3:i386 but it is not going to be installed
Recommends: libfontconfig1:i386 but it is not going to be installed
Recommends: libfreetype6:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgnutls30:i386 but it is not going to be installed or
libgnutls28:i386 but it is not installable or
libgnutls26:i386 but it is not installable
Recommends: libgsm1:i386 but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
Recommends: libkrb5-3:i386 but it is not going to be installed
Recommends: libodbc1:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libpng16-16:i386 but it is not going to be installed or
libpng12-0:i386 but it is not installable
Recommends: libsane:i386 or
libsane1:i386 but it is not going to be installed
Recommends: libsdl2-2.0-0:i386 but it is not going to be installed
Recommends: libtiff5:i386 but it is not going to be installed
Recommends: libv4l-0:i386 but it is not going to be installed
Recommends: libxcomposite1:i386 but it is not going to be installed
Recommends: libxcursor1:i386 but it is not going to be installed
Recommends: libxfixes3:i386 but it is not going to be installed
Recommends: libxi6:i386 but it is not going to be installed
Recommends: libxinerama1:i386 but it is not going to be installed
Recommends: libxrandr2:i386 but it is not going to be installed
Recommends: libxrender1:i386 but it is not going to be installed
Recommends: libxslt1.1:i386 but it is not going to be installed
Recommends: libxxf86vm1:i386 but it is not going to be installed
Output of apt file:
###### Ubuntu Main Repos
deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
Ubuntu Update Repos
deb http://archive.ubuntu.com/ubuntu bionic-security main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-proposed main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
deb https://deb.torproject.org/torproject.org bionic main
deb http://http.kali.org/kali kali-rolling main non-free contrib
deb-src http://http.kali.org/kali kali-rolling main non-free contrib
deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main
deb-src https://dl.winehq.org/wine-builds/ubuntu/ bionic main
Output lsb_release:
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="kodachi"
I tried everything and I saw another post : Can't install wine stable on Ubuntu 19.10 (depends on wine-stable)
But it's 19.10, I think I can also update it but I tried also apt autoremove etc.
